Indeed i am. if i was younger, i would have been embarrassed to post the photos of my crap welds, but at this point in life, what the h e l l. if somebody could get an idea from the photos, great. I haven't touched a welding machine in over 10 years. i just retired from a hectic public sector job that kept me busy for years. i am finally getting around to doing the things i used to like to do in my free time. i picked up a 1988 jeep wrangler that needs a bit of welding, so i will get a bit better hopefully when the weather improves here in NY
Results 11 to 20 of 49
01-04-2010, 11:46 PM #11
Member
- Dec 2009
- 62
01-05-2010, 06:00 AM #12
- Sep 2005
- CT.
- 332
01-05-2010, 05:06 PM #13
- Nov 2009
- sarasota,florida
- 23
Nice job JOE! Looks just as good as a retail unit. Keep up the good work. Darrell
01-07-2010, 04:34 PM #14
Hey Joe,
Thanks for the photos.
Nick
05-29-2010, 08:14 AM #15
- May 2010
- 1
hey, i made a blaster a few months back, it is similar to yours, the filler port is the same, 2" nipple and cap. how do you have the inner tube sealing the cap? could you take a pic? mines leaking, i tried a few diff ways to place the tube but it still leaks.
thanks
05-29-2010, 12:41 PM #16
- Sep 2005
- 4,247
I used a radius arm grommet from a ford pickup. pull it up to seal and when the pressure drops it opens. Used pressure washer hose for the blast hose and 1/8 xh pipe nipples for the blast nozzles.
There is a valve on the bottom to regulate the sand and I made long wand. I didn't use a dead man.
05-30-2010, 08:29 AM #17
Member
- Dec 2009
- 62
I know you solved your problem, but i will post this here for the benefit of those who might have the same question:
mine is not a perfect seal. It is good, but there is a slight air leak. It never bothered me enough to look any further into fixing it. I used a rubber circle of inner tube to fit in the cap.Millermatic 211
Everlast 200DX TIG
Lincoln Weld-Pak 100
Century Stick welder
Hypertherm Powermax 30 plasma cutter
Oxy set-up with Henrob 2000 torch
Logan 200 lathe (60 years old)
Jet band saw
05-30-2010, 12:29 PM #18
Member
- Apr 2007
- Colorado
- 35
Dope it
Smear some pipe dope on the threads - or teflon tape. The nipple probably doesn't butt up against the cap so the tube gasket won't help a lot.
Great job. Great idea. I'll put that on my someday list.
05-30-2010, 11:50 PM #19
Member
- Dec 2009
- 62
Yeah, i never looked close until i took this photo this week, the nipple does not seat up against the rubber piece, i guess that is why i get a leak. i don't want to use dope on the threads, the sand will stick when i fill through the nipple and will make like a lapping compound and wear the threads over time. i think i will put probably a half of a tube of latex or silicone sealant caulking compound in the bottom of the cap and let it harden to like rubber. that would most likely give me a better seal. Thanks
Millermatic 211
Everlast 200DX TIG
Jet band saw
06-17-2011, 05:44 PM #20
- Feb 2010
- 27
very cool project! have you ever thought of using 2 20lb bottles and cutting one in 1/2 and cutting the ends off another the take the 2 1/2 pieces and weld them on the section you cut the ends off then you will have more capcity. just a thought
