Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
    Default Pressure sandblaster from propane tank
    UPDATE 01/18/12
    Upon further reflection, and several friendly warnings from those more experienced in such things than me, i am removing all the original text from this post and warning others what a stupid idea this is, and it should not be undertaken if you value anyone's life. After reading the thread linked further down this thread regarding the danger of pressure vessel welding, i completely agree that it was way above my ability, and added to that fact, it was a rusty discarded tank to begin with. I wanted a project and I had the tank laying around, but I did not realize what a dangerous idea it was.
    To the several Brothers who objected to this project, especially tanglediver and Bearston, thank you for your concern and advice.
    I will concur with those advising not try this dangerous stupid project.
    Default these were cut out of previous message
    Default and the last two
    Finished and painted:
    CT.
    332
    Cool idea. I do not really understand the large top fitting though. Is this just a cap to fill it (what size is that NPT). Also why do you "T" it off and run a hose to the bottom "T". Is this how they are supposed to be. Is this just to induce air into the sand at the bottom "T". Also what is your safety blow-off set at. I might make one.
    T.J.
    Miller Dynasty 300DX
    HTP MIG 240
    HTP 380 Plasma
    Bridgeport Milling Machine
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    Quote Originally Posted by TJS View Post
    Yeah, that is 2 inch pipe cut off for a filler hole. You use a funnel and pour your media in then cap it tight, using a piece of an old innertube as a gasket.
    The air enters the tank above the media (sand) and forces it down and out the bottom, while at the same time, an alternate path of air is routed down outside the tank and then joins the flowing sand at the "T" fitting. This keeps the sand moving with required pressure.
    I put a 125 PSI safety valve for a safety blow off. My compressor just about reaches that pressure, and i use the plastic regulator to keep below 100 PSI. Since the photos, i replaced the washing machine water hoses with real hydraulic hoses i got from the Northern Hydraulics catalog. The blaster works excellent. I used to have a siphon type toy from Sears, It always clogged up and generally sucked. But this thing just blasts away rust and paint at an unbelievable rate. I use Black Beauty Abrasive, and i don't choke on silica dust anymore. This is one of the most useful projects i have built.
    Island Falls Maine
    562
    I have used a propane tank before to make a tire bomb to inflate truck tires
    1,565
    To add to the OP's explaination -- the valve under the tank is only opened part way to regulate the amount of sand that comes out. If opened all the way you usually get way to much sand. The valve on the end of the hose (where the sand comes out to blast) should be opened all the way or it will have a short life as the sand will wear it away quickly if used to regulate flow by leaving it part way opened.
    Dec 2009
    12
    nice looking blaster but if you you use it a lot it will wear through the t fitting on the bottom, on commercial unit the t is actually a 4 way fitting with a plug in the bottom so there is more material there to wear.
    Nov 2009
    Montreal, Quebec
    49
    Nice project Jonh and it's a good size for portable and small job. A use to be a sandblaster my self for 5 ears, 7 ears ago whit industriel big stuff!! Your kit is very cool , and y see that your a welder debutant seeing your welds
    Ricau
    XMT 304 cc/cv 208/480 volts
    Lincoln wire feeder LN-25 w/Contactor and Gas Solenoid, w/magnum 400 and 200 gun's (12 ft)
    Spoolmatic 30a w/Flex Head tube 10'' XRA
    Flexible Head Tig Torch w/Gas Valve (25 ft)
    Foot Control RFCS-14HD
    Side-to-side rotary-motion fingertip Current Control
    Miller process Selector Control w/external solenoid valve
    Stainless steel welding cart
    Makita LC1230 Dry cut saw
    www.ricau.ca
    To add to the OP's explaination -- the valve under the tank is only opened part way to regulate the amount of sand that comes out. If opened all the way you usually get way to much sand. ...
    Thanks for clarifying that point. You are completely right. if opened up too much, the blasting nozzle loads up with media and you get a real sh1t storm out of the nozzle when you hold the deadman lever, and a mess to clean up in the driveway.
