Results 11 to 20 of 21
    Dec 2009
    Northern California
    179
    Quote Originally Posted by SmokinPRanch View Post
    Another thought...
    Check out http://www.8020.net Their extrusions might be able to be incorporated into your concept.
    Keep us posted as you progress.
    Al
    I work a lot with the 8020 products and it is fine for static displays and fixtures but I would advise against using it as part of a fixture that would be moved or have sliding / friction surfaces as the aluminum wears.
    It is rigid but requires constant re-tightening and if things are moved about, the tend to "wiggle" the joints and things tend to wobble about after awhile.
    Sep 2009
    Alberta
    37
    I like your idea, you could probably get away with 1-1/4 into 1-1/2 tubing. its a bit loose but if you drilled some holes and welded some threaded nuts to the outer tube, you could thread in bolts to tighten up the table at whichever position you wanted. It kinda looks like you drew that in already. To reduce the risk of swayback you could opt to have your inner tubes be seperate pieces from your table frame which can simply be slipped through seperatly as you adjust your table, have them double up on each other for the entire length of the table (perhaps a shorter set for when you want the tables in the compact configuration)
    Honestly though, I think you will end up spreading out the table to its entire length for 99% of your work and you will probably be wishing you made a 1 piece top for it.
    Unless you need to fold it up and put the table aside after each project I think you will find yourself wanting a solid 1 piece flat table to work on.
    Cheers
    Thanks for all the comments. There a lot to consider. I don't think I need to make the cross bars a perfect telescope fit if I have welded nuts for clamp bolts (I'm thinking 5/8" bolts) on the outside tubes. The bolts can take up a vertical gap (between inside and outside tubes), so I could weld the nuts on the side with the seam, and put the gap there. I'd want to crank the bolts pretty hard to keep things solid and prevent sagging, so another consideration is I don't want the bolts to crush the inside tubes or distort the outer ones. Not sure what thicknesses are required for that.
    Most of the time, the limited space I have can't comfortably handle more than say a 32 x 42 table, but I'd like to make frames for benches and tables that might be 5ft by 3ft so it would be nice to clamp up the whole thing at once, and temporarily lose some room around the table. The posted ideas for add on or flip up side wings, or even separate tables, are something I need to consider.
    The whole idea came from looking at the $2k Stronghand Fixture table:
    http://www.trick-tools.com/welding_a...ding_Table.htm
    , but it of course doesn't do sliding width. I anyone else has ideas, please add them.
    Browns Valley, California
    1,713
    The idea appeals to me, but I've found it not to be necessary to have a solid table top for fitup of larger projects.
    I've often used sawhorses with two or three lengths of 3", 5# channel clamped at a right angle to them. The gaps between channels allow for access, and my clamp inventory is good enough most times to hold everything together for tack-up.
    The "bench" materials store easily when you're done.
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    Lodi, CA
    1,132
    If you want true 1/4" wall tubing for the outside parts, check Northern, they sell 12" and 18" long sections of receiver tubes ....
    Otherwise, use 3/16" wall for the outsides, turn them so the internal seams are on the same plane as the setscrews.
    Weld the nuts for the setscrews on the corners, not in the middles. This will give you more crush-resistance, plus more rigidity, since it's forcing the inside tube up against two surfaces, not one.
    2,641
    I would make the Main table solid and then just mount receiver tubes on the ends.
    Your Wings would then slide in to the receiver tubes on each end or just one, depending on the length you need.
    (although I bet it will be tough to make any Wing sit exactly flat with the main table)
    The wings could be 1/4" so yer not busting a nut. The wings don't need to be as heavy duty as the main table.
    Of course you don't have the Open table design but I agree wid the others- lots o' work to make the Sliding Table, work.
    Mar 2009
    234
    Ed's take is smart, especially from a KISS point of view. You could have the wings fold down, also. You could even have them swing up and lock into position with a gap between them and the main table, so you have an open slot for clamping whenever one of the wings is up and in position. A simple hinge is a lot easier to build than telescoping tubing -- easier to keep clean and functional, too.
    Here's what I meant with my interlocking top idea. It would actually be two three-legged tables that would fit together. You could slide them apart for more surface area, and in doing so open up more clamping space as the table gets wider.
    My idea is not smart, from a KISS point of view.
    It would be tricky to cut, too, unless you used assorted rectangles to make each top.
    Dec 2009
    Custer Park, Illinois
    92
    Quote Originally Posted by Kamikaze View Post
    Thanks for the clarification. I have limited experience with the 80/20 but knew they did some linear stuff. Never considered the wear issues of the aluminum.
    Al
    Sep 2007
    Medford MA
    525
    i made my top out of 1"x1" sq tube (0.125" wall) spaced about 6"
    apart. it's great for clamping things to. if i need a solid, flat,
    surface, i just lay a piece of whatever is convenient and fits the bill
    on top. even, on occasion, a piece of plywood
    frank
    Yah, I kind of reached this conclusion after reading the 1st round of responses. Make one solid center table with 4 legs and no funny stuff. Have receiver tubes run side-to-side to accept wings, or a vise holder, or whatever else I dream up. I then have something simpler and sag-proof to start with, but has some expandability built in. I'll toss up another drawing soon.
    I checked the price of hitch receiver tubing at local place, $114 for 6 feet. It sounds like a lot, but then I get to thinking that it's probably worth $50 (or whatever the cost is over seamed tubing) to not have to worry about the seam.
