Results 1 to 10 of 14
    Question hobart 140 or maxus 140?
    Hey guys, I was just thinking about getting a 120 volt welder to do light welding that is to thin for stick welding, I have been looking at getting a hobart handler140 or a maxus pro 140, has anybody used both of these and could tell me which which is better, the maxus looks more durable, but how does it weld, Ive welded with a hobart 125 and was impressed with what that little thing can do, i would appreciate any help, thanks
    [FONT="Comic Sans MS"]Just weld it!!! Miller big 40 diesel, Miller bluestar 180k,Maxus Pro-140 mig, Gas powered air compressor, and alot of tools the lady dont need to know about. all portable for on site work,15 year Structural welder,Ironworker, Millwright.
    2,927
    The HH140 has a solid reputation.
    Nov 2009
    Central Arkansas
    46
    I vote HH140. 13 8 inch rolls of wire and counting. most of it on tap 4. Never a hitch. The gas valve is solid and has never leaked from day 1. I have carried it to sights and run the dog out of it. I am pretty sure all the internal wiring on the HH140 is all copper. I have never had to crack the case on mine.
    Never seen a Maxis, so I can't speak for them.
    Rick
    Trying to succeed, Learning by failing
    HH210 (Merry Christmas to Me)
    HH 140
    Hyper Therm Powermax 600
    Hobart Stickmate AC/DC
    Forge
    Victor & Harris Oxy/Act
    HydMech 225 cold saw
    several grinders
    Rigid Chop Saw
    4x6 band saw
    Never enough clamps
    Sep 2007
    Medford MA
    542
    i looked at the maxus web site.
    while it's picking some very very small nits,
    i note that the welder comes with a "dual gauge with hose"
    even i know that it's called a regulator, and what i know about
    welding would fit into a very very small thimble. so i have
    to wonder what _they_ know about it.
    like i said, an extremely small nit.
    happy new year
    frank
    2,927
    Quote Originally Posted by fjk View Post
    happy new year
    frank
    Well they know it is a Gauge- a Flow Gauge Regulator
    hey guys thanks for you comments, I was looking at specs on these welders and i found that the MAXUS PRO 140 is slightly larger in size and weight then the HH140. The maxus was about 18 lbs heavier than the HH and and the machine is about 5" longer, 5"wider and 4" taller than the HH. So what im getting at, if the machine is heavier, that means more copper, Right? More copper means more windings and smoother arc Right? or is my theory wrong, what do you guys think., thanks for you input
    2,927
    I would be looking at either the MM140 or the Lincoln Power Mig 140c if you want more control of the Arc.
    Nov 2009
    Central Arkansas
    46
    The Hobart has a great warranty and support.
    Rick
    HH 140
    Forge
    several grinders
    Rigid Chop Saw
    4x6 band saw
    Never enough clamps
    Mar 2009
    234
    I've been very happy with my HH140.
    I don't know anything about Maxus, but a quick google search shows they're a new division of Campbell Hausfeld.
    Does anyone know where the Maxus units are made?
    Sep 2007
    Medford MA
    542
    Quote Originally Posted by reiser68620@yahoo.com View Post
    not proven.
    the weight could be a pile of lead in the base of the unit.
    or thicker sheet metal for the case
    or creative weighing by the marketing department
    or any of a number of things designed to make the machine
    feel like it's hefty, without costing a lot or doing
    anything to help its welding.
    or it could be more windings on the transformers.
    you can't tell without pulling it apart
    frank
Tags for this Thread
