Results 1 to 10 of 10
    JayM Guest
    Default Looking for feedback
    I recently bought a MM 175 and have been relearning how to weld. In the last few weeks I have welded just about everything I can to get some practice. I wanted to get some feedback to see if Iím getting any better and if Iím making some decent welds. Will to take any advice. I have included some pictures.
    S.W. Pennsylvania
    2,250
    When you post picture of youre welds you should include info on youre set up, wire size, feed rate, sheild gas, metal thickness and anything I may ave forgot. I'm not one to critique a weld but my first impreasion looks like you might have too much angle. I'm not a mig welder so dont put to much weight on my advice.
    Dont forget to post the amperage you are welding at.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    Jan 2006
    Antigonish, Nova Scotia, Canada
    33
    it kind of looks like you have you wire speed too high and too little amperage. also your travel speed may have been a bit too fast. but I could be wrong, if you tell us your settings and everything that burninbriar mentioned we can help you better.
    Hope that helps,
    Charles
    Feb 2006
    Beresford N.B., Canada
    46
    If that were done with a stick welder, you could say there's not enough penetration.
    Save our species! Lower metal prices!
    Feb 2006
    Eastern Washington
    14
    I don't think youre that far off. I would slow down your travel speed and bump your wire speed down a bit...then post a few pics. Really it's hard to say...I'm one of those that welds more by sound and feel than what the dials are set to...
    Feb 2006
    411
    Jay,
    just keep practising, it takes time to learn it. but you are doing the correct thing by asking questions. just keep at it and asking others knolige and you will get their.
    and you got a Blue machine, Thats the Best!
    Oahu, Hawaii
    2,469
    Default Wirespeed IS the amperage!
    On the MM175, you have one knob voltage, one knob wirespeed. Wirespeed controls the amperage. Try moving in circles, it'll lay flatter. Write your info and we can help you better. The MM175 is a GREAT machine!!! .035 wire with argon/co2, do a 3/8" plate, and bend test...FLAWLESS!!!
    I'm not late...
    I'm just on Hawaiian Time
    Deltaville, VA
    2,239
    Jay,
    Try pushing the weld vs pull. You'll get slightly less penetration, but a flatter bead.
    Might also go up one on the V setting. Looks like you could use a little more heat in the weld. Where are you (settings wise) relative to the door chart for the thickness material you're working on.
    While learning, I've found it sometimes helpful to use a guide to keep the bead straight. That way you can focus on the puddle and travel speed.
    Lake of the Ozarks MO
    3,596
    Dudes...this is a 2 year old thread...he either got the hang of it or gave up
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Oahu, Hawaii
    2,469
    yeah! Isn't it funny? I caught that too! Probably a drawback from what McDoogle did and how Admin had to cancel all his posts! Gives some of us new guys to get the old info that you more experienced guys gave and put that in my book!!!
    I'm not late...
