    Oct 2005
    Nashville, TN
    68
    Default Adjustable A-Frame
    This is a lifting A Frame used in our control panel fabrication shop. I built this after looking at the commercial versions that were available and not being impressed with their features or cost.
    This unit features hydraulic cylinders for engine hoists incorporated into the vertical uprights to allow convenient height adjustment. Unit is adjustable from 8 1/2 to 10 1/2 feet high.
    First picture is A Frame with chain hoists, second is close up of hydraulic adjustments, third is detail of attachment between uprights and I -beam.
    Comments welcomed.
    Synchrowave 180
    Millermatic 210
    Spectrum 375
    Nov 2009
    Montreal, Quebec
    49
    Very nice Yvan, a like it and im sure it's very handy, sometime the product exist but we can always adapt it for our use when its us who built it
    ricau
    XMT 304 cc/cv 208/480 volts
    Lincoln wire feeder LN-25 w/Contactor and Gas Solenoid, w/magnum 400 and 200 gun's (12 ft)
    Spoolmatic 30a w/Flex Head tube 10'' XRA
    Flexible Head Tig Torch w/Gas Valve (25 ft)
    Foot Control RFCS-14HD
    Side-to-side rotary-motion fingertip Current Control
    Miller process Selector Control w/external solenoid valve
    Stainless steel welding cart
    Makita LC1230 Dry cut saw
    www.ricau.ca
    Island Falls Maine
    562
    they come in handy dont they.
    1,565
    Very nice job. The hydraulic jacks is a good idea, never saw that set up before. The one I have lets the upper tube slide through the lower tube & you hook a come-a-long to it to raise or lower it.
    Aug 2005
    Chino Valley Arizona
    43
    Very nice, I like it!
    Econotig
    MM175
    Nov 2009
    Central Arkansas
    46
    SWEET! Have the jacks caused any issues so far?
    Rick
    Trying to succeed, Learning by failing
    HH210 (Merry Christmas to Me)
    HH 140
    Hyper Therm Powermax 600
    Hobart Stickmate AC/DC
    Forge
    Victor & Harris Oxy/Act
    HydMech 225 cold saw
    several grinders
    Rigid Chop Saw
    4x6 band saw
    Never enough clamps
