Yes it does say Canadian Forces. Spent 27 years Reg Force am now a 12 day month Reservist. The platforms are made of Cabinet grade veneer plywood. Since I do a lot of woodworking as well I had these pieces lying around that were cheaper than buying flat plat for the platforms. As long as I don't weld to close to the stand the sparks should not cause a problem
HHM
Results 11 to 17 of 17
12-29-2009, 04:35 PM #11
- Nov 2009
- Ontario Canada
- 41
First project
Harold Mulder
Millermatic 211 MVP
HTP Invertig 201 with water cooler
12-29-2009, 07:38 PM #12
12-30-2009, 06:14 AM #13
- Sep 2007
- Medford MA
- 525
Harold -- Nice cart. Looks well made.
With regards to fire, I'd worry more about the wood dust in the
shop. Look at the last picture in Harold's original post; there's
plenty of saw dust around what looks to be a very nice table saw.
I generally suggest to folks who do woodworking and want to
add metal fab & welding that they do their metal work in another
area (such as a garage). The fire risk is one reason. Another
is that grinding, etc, of metal creates a lot of very abrasive
grit that would get everywhere and absolutely demolish
unprotected tools/mechanisms and edges of planes, chisels, etc).
Frank
12-30-2009, 10:44 AM #14
- Nov 2009
- Ontario Canada
- 41
First project
Thanks for the points. I thought about coating the wood with a thin veneer of metal and may still do that down the road. However I will need to find a cheap material since when I was in some of the box stores the price of thin gauge metal was outrageous. As to the sawdust I know what you mean I actually have two fire extinguishers mounted on the wall of this 22 by 22ft garage just in case. I was in such a hurry to build my first project after buying the 211 that I couldn't wait to carefully clean out the shop
. Before the next project though I will be cleaning it and I also plan to build some 5to6ft high shielding panels so that when the weather warms up I can also work outside on the driveway.
Harold Mulder
Millermatic 211 MVP
01-01-2010, 01:39 PM #15
looks good and keep up your good work
01-02-2010, 08:56 PM #16
- Dec 2009
- 62
01-03-2010, 05:07 AM #17
- Nov 2009
- Ontario Canada
- 41
First project
Might just try that especially since my 6month old F150 is going into the body shop to be repaired after I was rear ended visiting my Grandmother a month ago. Since they are replacing a side panel on the box I should have plenty of practice material out of that
. Any way thanks for the idea.
All the best.Harold Mulder
Millermatic 211 MVP
