Results 11 to 20 of 40
    857
    I built this with the folks on the Hobart Forum a few years ago. It is an small compact 1/8" bending brake. As designed, its max capacity is 6" wide. I've bent 6" wide HR steel with it, and it actually worked Ive also bend 4" wide 304L SS. Mostly though, I use it to bend 2" and narrower stock, which it does nicely with very little effort.
    The bending brake was a great challenge, I built one too. The Hobart Forum is a great recource. Here's mine...I trimmed the bender leaf to accomodate shorter bends.
    See more HERE
    Arcin' and Sparkin', Rocky D
    "Experience is the name we give our mistakes"
    21
    Default Welding projects...
    Hello! I just got on this and have high hopes! I am a High School welding teacher and am ALWAYS looking for smaller projects that the kids can build. Both useful things for themselves, or good shop projects.
    Thanks, got to run the kids are getting here!
    3,946
    Try this group for some neat ideas. You will need a cheap HF bender, 49 bucks for most projects...Bob
    http://groups.yahoo.com/group/ornamentiron/
    Rocky D,
    I like the Welding Finger. What the best way to make the weight block? A solid block may be difficult to find. Make a box out of thin plate material and fill with something heavy? Thanks.
    Sep 2002
    Clark County, NV
    2,696
    Quote Originally Posted by NorthernLights
    Rocky D,
    That would certainly work. You can get creative and use other shapes, too. Depending on how professional you wanted it to look, you can use a weight bench weight and weld a a big bolt or something through the middle hole to keep it on the finger, even a brick with some way to hold it on. Even without a weight, it would still work for some of the more delicate holdings.
    Plymouth, MI
    475
    This is my version of the welding finger (based on Rocky D's)
    Bob Sigmon
    ___________________
    Dynasty 200DX w/ Coolmate 3
    Miller Passport
    LMSW-52T Spot Welder
    A/O Setup with Meco Midget
    Miller Big Window Elite
    Quincy QT-5HD
    Houston, Tx
    24
    I made two of Rocky D's welding fingers. One out of 3/8" round bar and one out of 1/2" stock. I did not put a weight on them, but I think they work fine anyway. I also made a plasma cutting grate based upon his design with the removable cutting fins. It works great, highly recommended if you have a plasma cutter.
    563
    Some really great projects here. Rocky D I noticed your`e Hobart is autographed,who are those that helped with the decorations?
    3,946
    Here's my version of a welding finger clamp thingy. I use about 20 of them on one welding jig to hold the little parts. They are simple and cheap to make from a small od sq tube. I used 3/8" sq. They slide up between two rails and have spring pressure downward. Sure beats buying 20 pairs of Vise grips...Bob
