A make a deal whit my client to built a welding cart whit is extra stainless steel tube an exchange for use my welding kit. So a design a new model to fit in to space less to 18 inch width and in to my car or on the roof rack. I buil it in 2 weeks at 1 hrs each day after or before my normal day work. A did copy a little the Miller but a built it on the other side
Im just wondering how im gonna polished all the frame for a nice shining finish. A use a grindin brusch for arround the welding. Hope someone out there have some advise for the polishing, tank's
Thread: Stainless steel welding cart
12-19-2009, 12:57 PM #1
XMT 304 cc/cv 208/480 volts
Lincoln wire feeder LN-25 w/Contactor and Gas Solenoid, w/magnum 400 and 200 gun's (12 ft)
Spoolmatic 30a w/Flex Head tube 10'' XRA
Flexible Head Tig Torch w/Gas Valve (25 ft)
Foot Control RFCS-14HD
Side-to-side rotary-motion fingertip Current Control
Miller process Selector Control w/external solenoid valve
Makita LC1230 Dry cut saw
www.ricau.ca
12-19-2009, 01:49 PM #2
Ricau,
You never mentioned what series of Stainless Steel you were using, or if it was textured with a Satin Finish, but I am guessing that some good quality metal polish, and something like a Mothers PowerBuff ball mounted in a drill will do a very good job for you.
After a little elbow grease (or drill time) you should have the results you want, plus the polish should help seal the metal to give you a long lasting shine.
I visited your website, but unfortunately, I do not speak a word of French.
Have a Good Day.Later,
Jason
Professional Spark Generator by Trade.
12-19-2009, 04:06 PM #3
http://www.lehighvalleyabrasives.com...ng-Disc/Detail
I have also used 800 grit Wet/Dry sand paper with thee ol' Elbow grease.Ed Conley
12-20-2009, 06:45 AM #4
- Dec 2009
- 8
I agreed with you , to paint stain less steel try to use a high quality, oil-based paint, and either spray, brush, or roll it on it depends whar final texture you wants your frame in, best of
12-20-2009, 09:02 AM #5
IM not sure about the stainless steel serie's but it not high quality like 306L becose it was just for building frames. And it was not textured with a Satin Finish, just regular boring finish, we can also see the welding strip on the tube. Tank's for the advise and now im gonna try buff and seal this cart and when it's done, a will show some pictures.
Tank's Jason to visited my website and in the near futur, my plan was to convert it to Bilingual. But i have to give to a professionnal website creator whit a differente page, becose a make it by my self whit not a lot of experience,and some appearance suggests, and fiuu,,it's long and boring to create a page,,, It was a good start, but now it's need a better structure for the new years 2010 to come
RicherXMT 304 cc/cv 208/480 volts
www.ricau.ca
12-24-2009, 11:38 AM #6
Thats nice and handy.
