Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
    3,955
    Cool Brass Chandioler meets a 25' drop!
    A nice little project that came in today. A giant 100 lb 4' tall brass chandioler that cost 5 grand in 1984 fell 25' and smashed. It should be a pretty easy fix it just looks bad all mangled. I need to make a new rod that goes up thru the middle for a frame and weld brass tabs on the arms and redrill the holes to mount. The pcs on the left with the blue tape are fine. Hopefully i don't have to mess with the wiring too much...Bob
    Vancouver BC Canada
    605
    ouch! good thing it didnt hit anyone... did it "just fall" or was there something to entice it to come loose?
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    3,955
    Quote Originally Posted by SignWave View Post
    I was first told it just fell. But when i picked it up i was told they use a hook to pull it over to the 2nd floor to change the bulbs so it may have been pulled...Bob
    Vancouver BC Canada
    605
    hehehe... sniker sniker. Well enjoy the rebuild.. if you have any wiring trubs let me know, I'll do what i can to help you out.
    Syncro200
    Spectrum 625
    O/A
    54" laminator
    little dog
    Vero Beach, fl.
    761
    With the kind of work I've seen you do, it will look much better than new in no time. Dave
    Honolulu, HI
    103
    Kind of reminds of on those high school physics problems:
    "A giant 100 lb 4' tall brass chandioler that cost 5 grand in 1984 fell 25' and smashed. What was the speed of the chandelier at impact?"
    Ouch! My head hurts...
    May 2007
    Dallas, Texas
    323
    Quote Originally Posted by jonnymag View Post
    Simple to solve for time.
    s= Vo2 (v naught squared) + 1/2 at2 (at squared)
    Where s= distance
    Vo2 = initial velocity squared
    a= acceleration, 9.8 feet per second
    t2= time squared
    25 feet = 0 + 1/2 x (9.8 x 9.8) t2
    25 = 1/2 x 96.04 t2
    25= 48.02t2
    .52061641=t2
    .721537532=t
    It takes .7 second for the chandelier to fall 25 feet. I don't know how to figure out what the velocity was at impact.
    Millermatic Passport Plus
    Millermatic 350P with Python
    XMT 304 /w S-64 feeder and 12VS
    Dynasty 300 DX
    Thermal Arc 400 MST
    Premier Power Welder for my trail junk.
    Vancouver BC Canada
    605
    Default E=mc2
    25 ft/sec. should have been the velocity @ impact. In the first second, that chandelier would have accelerated to =32 ft / second, so 25ft in one second should = 17mph...? I think this is right. It failed Physics... was too busy chasing the girls getting 'A's in the subject...
    So with that all said and done, how much did it weigh at the time of impact? hehehehe..
    Syncro200
    Spectrum 625
    O/A
    54" laminator
    little dog
    Honolulu, HI
    103
    I'm not sure about everybody's math, but assuming crawler's calculations of time are correct -- if it fell 25ft in 0.7 secs, then wouldn't that mean it would have fallen 36ft in 1 sec? (25ft/0.7sec = x/1.0sec; 35.71ft/sec=x)
    Now I'm gonna be having slide rule nightmares again
    Jul 2007
    Lancaster, Pa
    431
    Well, keep the slide rule handy cause Im wondering how much damage it can do on a human scalp at 25ft/.7sec vs 36ft in 1sec or whatever speed it was going
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
