Results 1 to 3 of 3
    Nov 2009
    Montreal, Quebec
    49
    Default Wake board tour w/spoolmatic 30a
    Hy, just feel to share whit you my first aluminium job made whit spoolmatic for my boat whit 50hp, but not enough power to lift a guy out of the water. A have fun built it aneway
    XMT 304 cc/cv 208/480 volts
    Lincoln wire feeder LN-25 w/Contactor and Gas Solenoid, w/magnum 400 and 200 gun's (12 ft)
    Spoolmatic 30a w/Flex Head tube 10'' XRA
    Flexible Head Tig Torch w/Gas Valve (25 ft)
    Foot Control RFCS-14HD
    Side-to-side rotary-motion fingertip Current Control
    Miller process Selector Control w/external solenoid valve
    Stainless steel welding cart
    Makita LC1230 Dry cut saw
    www.ricau.ca
    Jan 2007
    South Carolina, Dixie
    515
    Default Spool matic wakeboard!
    Wow. I would't have thought of that. I'm sure I would TIG this thing up if I was trying to build it. I work on boat towers, railings and all sorts of fabrications from aluminum pipe, etc. Nice. Too bad about the motor thing. Maybe a lrger one would work IF the boat could handle it.
    Mustangs Forever!
    Miller equipment.
    Jan 2009
    Ohio
    191
    Thumbs up Wake Board
    Nice job makes the boat look great.To bad it doesn't work like you wanted Maybe this was a good start on next one. Still great job any ways.
    Vernon
