Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    2,636
    Start looking for John Deere Gators
  2. #22
    Jan 2009
    13
    Joey2589, did you Google the Pug Badlands? I think you might get some ideas from it.
  3. #23
    Apr 2006
    Mission Hills, CA
    48
    yea i looked it up. its articulated which seems more of what your project will be. for mine i was going to try a solid front steering axle like a jeep would use.
    78' Miller AEAD-200LE
    08' Miller Matic 180 Autoset.
  4. #24
    Sep 2008
    southwestern ohio
    272
    Whatever you do keep the Ford 9". They are virtualy bulletproof and in your aplication the only way to deystroy it would be to run it without oil.
    This is an automotive discussion forum that has some great infromation
    www.autobodytoolmart.com/shoptalk
  5. #25
    Apr 2006
    Mission Hills, CA
    48
    oh yea the 9" is staying for sure unless a unrepairable issue comes up.
  6. #26
    Jan 2009
    13
    Joey2589,
    Pug also makes 4 wheel drives with front wheel steer. Take a look around there website. The Ford 9" differential are very tough and parts are cheap. I'd bet a guy could just grease up the ring and pinion and never burn it up for a low speed (25 mph tops) application like we are talking about.
  7. #27
    Sep 2008
    southwestern ohio
    272
    Quote Originally Posted by vpd66 View Post
    Joey2589,
    If you went that route I would pack the bearings the way you would wheel bearings. It would be so much easier to just fill it up with 90wt.
