A Circle Burner For My Victor Torch. Burns 1/2" To 9" Holes Easy To Use I Can Cut Perfect Circle. Can Remove In Min. And Go Back On To Cut Same Size Hole As Before Works Off A Center Point.I wanted Something Lite.I Took A Split Set Collar And Tig It To A Pcs Of Flat Bar Than Milled A Slot Long Ways In The Flat Bar.Than Bent The Rear Up To Fork It Around The Torch. Than Took A Pcs Of 1/4" Round To Make Pivot Point, Threaded For Two Nuts. Than Made Off Setting Leg In 1/4" Pcs. Check The Pic
Vernon
Results 1 to 10 of 12
11-24-2009, 06:41 PM #1
Small Circle Burner For Torch......
11-24-2009, 06:49 PM #2
- Apr 2008
- 171
i like that
11-24-2009, 07:19 PM #3
- Feb 2007
- West Farmington, OH
- 746
So do I!!!
Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
11-24-2009, 08:08 PM #4
- Jun 2009
- greenfield new hampshire
- 783
very nice work, great idea, from the looks of it i bet the cuts come out perfect
11-24-2009, 11:11 PM #5
torch circle cutter
Nice job Dude, looks professional!
Professional firefighter (retired). Amateur everything else I try to do...
Oh yeah: GO BIG RED!
11-25-2009, 05:22 AM #6
dose it only cut one size hole or can it be set for diffrent sizes
11-25-2009, 05:40 AM #7
If you look at the second pic it is slotted so you can move the pivot for different size holes & then tighten it with the two nuts. These type of circle burners give a very nice accurate cut. Been using a similar one for years.
11-25-2009, 05:47 AM #8
Cirle Burner
11-25-2009, 05:50 AM #9
11-25-2009, 11:48 AM #10
My Drawling for circle burner
Here is the blue print I made to build the circle burner.
