Thread: Rusty fountain
    Nov 2009
    Cincinnati
    68
    Default Rusty fountain
    This fountain was the prototype for the green sculpture, I wanted to try the compound curves on some scrap first.
    I love the rust formations, they change every day.
    The ball is copper, it's an old float valve.
    Scottsdale, AZ
    173
    how did form up the part below the ball?
    Don
    Scottsdale, AZ
    www.savagesun4x4.com
    MillerMatic 211 AS
    Hypertherm PowerMax30
    Bernard 300 Amp Q Gun
    Bernard 200 Amp Q Gun
    Milwaukee Band-saw/stand
    10 Angle Grinders 8, 4 1/2" -2, 7"
    DeWalt Chop Saw
    Craftsman Twin-Blade Saw
    12 Ton Shop Press
    Optrel Satellite Helmet
    Miller Elite Helmet
    Nov 2009
    Cincinnati
    68
    It cut the two sides out of 1/8" , then I cut a 3" wide strip for the front, and a 10" strip for the back.
    I welded both sides down to the table, then started welding the front strip on, about an inch at a time, after every inch of weld, I had to re-clamp the next few inches.
    I cut a bunch of cheap c-clamps in half, and welded them on.
    The front was pretty easy, the back one was the hard part, I had to roll it to the basic shape, then start welding, clamping, and welding, etc, etc. In a couple of the inside curves, I had to drill through front,and back, and use a threaded rod to pull it in tight, The bar clamps I was trying to use just wouldn't hold with all the tension, and irregular angles.
    The easy way out would have been to trace the shape of the back, but keeping it 10" wide through all the curves was fun !
    Before I decided to add the ball, it went about another foot higher and came to a point.
    Dec 2008
    Arizona
    801
    Looks pretty cool, how long before it rusts through?
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Nov 2009
    Cincinnati
    68
    I think the rust is working like a protective coating ( Like cor-ten steel ) If I chip off a piece of the heavy rust, the base metal has a nice black coating.
    Maybe the copper has something to do with it,
    Nov 2009
    7
    It looks good. I like it.
