Thread: Aluminum Case
    Sep 2009
    South Carolina
    571
    Default Aluminum Case
    Guys I have an aluminum case here that needs a couple patches. I don't see a problem with the patches but the guy wants diamond plate added to cover each side. It is 10" X 18" and aprox. 1/16 thick.
    With it having to open and close on a hinge, I'm trying to figure out if there will be too much warping when trying to weld all the way around the plate on the outside.
    Here is a short video of it.
    What do you think?
    http://www.youtube.com/watch?v=se3dTgrVDBg
    Dec 2008
    Arizona
    812
    I think I would just glue some .040 diamond plate to the sides and forget about trying to weld it on.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Raymore Missouri
    1,922
    Or.......use some soft aluminum button head rivets. Those might look nice.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Apr 2008
    171
    yes alum. rivets
    Sep 2009
    South Carolina
    571
    Yea the rivet option sounds like the best idea. It has rivets in it now and they look to be sealed with some sort of plastic.
    The holes came out ok. The inside will have foam for the pistols, I'm pleased enough with the outside. Check it out if you like.
    Thanks for the replys.
    http://www.youtube.com/watch?v=an-9Ozpcj3c
    National City CA
    1,086
    How much are you going to charge him?
    For $200 he can get a new case made from aluminum diamond plate with the foam interior.
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Auto shades are for rookies
    www.KLStottlemyer.com
    Raymore Missouri
    1,922
    How did you fix it?
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Lake of the Ozarks MO
    3,594
    Red face Skip one day and look what happens
    I would'a slapped that diamond plate on there and welded it up in a heartbeat. And most definetly took his MONEY
    Rivets.... the guy came on here (a WELDING forum) to ask about welding and he got advised to rivet!!
    He obviously found someone who knew what they were doing.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Sep 2009
    South Carolina
    571
    How did you fix it?
    Still waiting on an answer. If he brings the plate, guess I'll end up welding it if thatís what he wants.
    I think it's fine with the holes fixed. The rivets in it now have some sort of plastic sealer involved and there is a seal where it closes. It will be weld a few seconds and cool with a wet rag then repeat. Takes forever.
    Its a strong enough case for guns, but its a fragile case when welding on it. So far there isn't one grounding clamp mark on it, but that could change in a hurry.
    Has nobody done anything like this? I know aluminum welds can shrink around 6 percent so I'm still concerned about this thing opening and closing right.
