Results 11 to 20 of 20
    Nov 2008
    27
    Quote Originally Posted by nfinch86 View Post
    Bob, Yes I agree, I have 30ft. of hose to my mig !
    It's good for when I'm on a mobile Weld job , I leave the tank on the truck & just have to move the Welder !
    ............ Norm
    How much gas does it take to purge the air out of lines. I thought about doing that but thought I would waste a lot of gas.
    Nov 2009
    Minneapolis, MN
    16
    Quote Originally Posted by Diverdude View Post
    As far as I know the only bottles you can't lay down are Argon and Propane for cutting ... 8<....
    I think you mean Acetylene not Argon.
    Nov 2009
    South Alabama
    255
    Yes bluejay you are correct, I get a little deslexic when I type. It sould say Acetylene. I believe pure CO2 also fits, just not flamable.
    "The only source of knowledge is experience." Albert Einstein
    Nov 2009
    Minneapolis, MN
    16
    I read it as you meant it not as you wrote it, did a double take and almost let it go, then thought that since this is a public forum that could be misconstrued in the future by others that don't know the difference that there should be a correction. http://www.msha.gov/alerts/hazardsofacetylene.htm
    Jay
    Lake of the Ozarks MO
    3,446
    Co2 can go either way depending on whether or not it has a siphon tube for using inverted.
    A lot of carts have the welding tipped up so you can read the dials easier but if you look at the bigger more powerful Miller welders the leads are turned downward so they are less apt to kink. So facing more down would be better... just harder to read the dials. Making yourself a "strain relief" would be the best option for the typical little welder on a cart.
    As for the hose purging question goes...once you flow/purge between the regulator and the machine you are good untill you break the seal because of the gas valve being IN the machine. You "waste" dozens of times more gas every time you stop welding because air goes back inside your gun assembly.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Diverdude,
    I'm not sure what to make of your signature. Guess I'm gonna have to find a new signature now.
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
    Nov 2009
    South Alabama
    255
    Just some thing different than listing a bunch of tools that would make my post twice as big. the guys at work are always looking for interesting old quotes. next good one I find will get it changed.
    Diverdude,
    I was trying to be sarcastic about your signature, hope I didn't come off as being serious about changing it. I seen that on a t shirt this past summer and had to use it.
    Jan 2009
    Ohio
    191
    Default Welding Cart
    Here is my cart, I know its a different mach but has large wheels and rolls easy. Maybe can use some ideals or not. Hope you find what works for you
    Vernon
    Sep 2008
    southwestern ohio
    272
    Default copycat
    Nice cart.That looks just like Miller's cart except for the wheel setup. I personally like the design of Miller's better because of the pnuematc tire and the fact that the welder is ballance on two big wheels and suported by two smaller ones.
    This is an automotive discussion forum that has some great infromation
    www.autobodytoolmart.com/shoptalk
