Results 1 to 10 of 16
Thread: Angel wings
    612
    Default Angel wings
    This is sort of a CNC or metal shaping or welding thread ...
    or all of the above.
    I am making a pair of Angel Wings for the upcoming Christmas Program. I'm cutting the wings out of foam on the CNC.
    While the router was running this afternoon I made the harness. Sort of an R-3 for wings. lol
    Bead roller pic. is a little too fuzzy to tell what it is. But, if you've seen one HF bead roller you've seen them all.
    Used the press & a scrap piece of strap iron to punch out the harness belt slots.
    This is where the welding comes in......I welded the brackets to the harness. lol
    The aluminum tabs will fit between the foam layers & get screwed to the brackets on the harness with self tapping screws so the wings can be positioned right.
    Nov 2009
    South Alabama
    255
    That is really neat, what kind of CNC is that? Is it a router or some other kind of cutting device?
    "The only source of knowledge is experience." Albert Einstein
    612
    Thanks Diverdude. It's a router I use in my sign business. I've had it for years,but just upgraded to the 3-d software.
    banning ca.
    135
    that is cool
    i really would like to get or make myself a cnc router and 1 for plasma
    hmmm? could you use the one you have with plasma aswell or is just for routers only?
    gary...
    Raymore Missouri
    1,906
    Quote Originally Posted by pro70z28 View Post
    What 3d software did you get? I have Aspire from Vectric
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    612
    Quote Originally Posted by glh View Post
    that is cool
    gary...
    Yup, the servos will move anything you attach to them. Possibilities are limitless.
    612
    I have Aspire V2 also. These wings are the first job for the new software. It's a pretty cool program.
    Raymore Missouri
    1,906
    Yeah it is cool. It can do so much it's hard to keep up unless you use it every day. I used the 3d to cut my rotor blades for my ultra lite heli project. Did you have V Carve and then upgrade or just buy Aspire. I got V carve in 2007 and in Jan of 2009 paid the $900 to get Aspire while they had the promo on. Had I waited two more weeks it would have cost $1450. I think new is $2000.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    612
    No, I was using the 2-d program that came with the CNC. Basically just a driver program. I do all my designing in Flexisign & import DXF files to be cut. Aspire is all new to me. It looks like it has all kinds of potential.
    Raymore Missouri
    1,906
    What impressed me is that you can design your own 3d projects in Aspire. . They have a lot cheaper program called Cut 3d but you can't design 3d. If you have to start buying 3d files anywhere from $10 to $50 each.....that can add up real fast.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
