I have a 1ton HF chain hoist.
With any more than a couple of hundred pounds on it will spin down -
it won't hold the load stable. Soon to be replaced !
You might want to check these suppliers -
Hoists Direct on Ebay,
Enco - http://www.use-enco.com/CGI/INSRHM?K...FQWcnAodNjUkSQ
Surplus center - https://www.surpluscenter.com/home.asp
Results 11 to 19 of 19
Thread: pic
11-22-2009, 04:05 AM #11
- Nov 2005
- 130
11-22-2009, 05:06 AM #12
For what it's worth, I've had the one ton HF chain hoist for several years now and it has done all that's been asked of it including lifting a box body off an old trailer frame. Never had a problem with it. I say buy one, test it close to its load rating and if it doesn't hold, take it back. I'm sure you're old enough to know how to do it safely. If not, you probably wouldn't have lived this long.
I like the gantry idea. You should be happy when you build it. Good luck and have fun.
11-25-2009, 10:26 AM #13
- Nov 2009
- Kentucky, Go Big Blue!
- 6
New updates! Got some presents from fedex
Harbor Freight 3 ton Chain Hoist (10ft lift)
Evolution Rage 3 Miter Saw & KnKut Drill Bit set
1/2" Stainless Bolts , nuts and washers, Grade 8.
-Old 1980's Miller Buzz Box stick
-2007 Millermatic 210 AMP MIG "Big Blue"
-2009 Millermatic 140 Autoset welder
-2009 Syncrowave 250 DX with Cooler "The boss"
-2009 Spectrum 375 X-treme
-Ingersol-Rand 7.5 HP 80 Gallon Compressor
-Ingersol-Rand Air tool fanatic.
-Matco Toolboxes & Handtools
Kentucky Wildcats...GO BIG BLUE!!
11-27-2009, 05:46 PM #14
nice welder. I need to buy a tig welder for the shop. all I got for a tig welder now is on the portable.
11-27-2009, 06:47 PM #15
i need to know your FEDEX guy. as for wheels i found tractor supply had great prices.
http://www.tractorsupply.com/tools/m...swivel-3592014TB 302
dynasty 200sd
spoolmatic 30a/wc24
suitcase x-treme 12vs
miller 211
evolution rage 2
11-27-2009, 07:19 PM #16
What is the Woodworking saw doing in this thread?
11-27-2009, 08:05 PM #17
- Dec 2007
- National City CA
- 1,086
They don't make grade 8 in stainless.
Grade ratings apply to carbon steel bolts onlyMiller Syncrowave 200 W/Radiator 1A & water cooled torch
South bend lathe 10LX40
K.O. Lee surface grinder 6X18
Auto shades are for rookies
www.KLStottlemyer.com
11-29-2009, 08:35 PM #18
Ed,
Product Details
-Patented RAGE technology: Cuts Steel, Aluminium, Wood & Plastics easily without compromise
-Faster and cleaner cuts than an abrasive saw. The RAGE3 leaves no burr and offers an instantly workable finish
-Economical performance, the RAGE blade system will produce up to 250 cuts in 2" mild steel box section (internal test data)
-No coolant required and virtually no sparks are produced
-Compound tilt and slide mechanism offers a solution to almost all common applications
-The Hi-torque gearbox reduces motor stresses, improving performance and durability
-High quality construction with 2 Year warranty
Blade included
Technical Specifications
Motor (115v ~ 60Hz) 2000w (Soft Start)
Speed 2500RPM
Max Depth Cut (90 deg Bevel) 3"
Max Depth Cut (45 deg Bevel) 1-9/16"
Max Width Cut (90 deg Miter) 11-13/16"
Max Width Cut (45 deg Miter) 8-1/4"
Duty Cycle 30 mins
Overall Size (HxWxL) 23-5/8" x 20-5/64" x 30-45/64"
Weight 39.3lbs
Sound pressure under load 98.0 dB(A
It is a multi-purpose saw.
11-29-2009, 08:40 PM #19
