Well I shot from the hip using dimensions I've used in the past. And granted I believe my w14X43 is actually a 2 ton beam not a one ton so yeah a bit of over kill.
As for the trolly Well it depends on what you want to do and what you consider expensive.
I have a 2 ton Cm loadstar with trolley in my shop looking for a home I'd be willing to part with it for cheap. It has a wide flange trolley on it.
As for buying one well it would be cheaper to buy a hoist with a trolley attached. A yale or budget hoist would run about $1500 for a 1/2 ton unit.
Our XN chain hoists with trolley would run upwards of $5K
So yeah things can get expensive.
How much money do you plan to invest in this?? Crane systems are nice .... Nice and expensive
Place four columns in your garage. Columns should have a 10x10 base plate with 3/4" anchor bolts spaced 7x7" into the concrete floor min four inch depth. Span the top of the columns with w12x14
then run a w12x14 from front to back of the two headers drill through and bolt all in place using 1/2" A325 bolts and nuts.
This would give you a freestanding monorail system that could be rated for 1 ton. Load testing would be required
Results 21 to 30 of 37
Thread: Steel Beam for Garage
11-21-2009, 09:46 AM #21
- Dec 2007
- National City CA
- 1,086
Miller Syncrowave 200 W/Radiator 1A & water cooled torch
Millermatic 252 on the wish list
Bridgeport Mill W/ 2 axis CNC control
South bend lathe 10LX40
K.O. Lee surface grinder 6X18
Over 20 years as a Machinist Toolmaker
A TWO CAR garage full of tools and a fridge full of beer
Auto shades are for rookies
www.KLStottlemyer.com
11-21-2009, 04:14 PM #22
Member
- Aug 2009
- 59
11-21-2009, 04:32 PM #23
- Feb 2009
- Lodi, CA
- 1,126
11-21-2009, 06:18 PM #24
- Dec 2007
- National City CA
- 1,086
That ain't gonna help ya if a 500 lb beam comes falling on your head. The only thing it would be good for is to read the name on it so they know who was killed
11-21-2009, 08:21 PM #25
- Sep 2005
- 4,246
Another wayyyyyyy overkill thread,,, hahahaha
11-21-2009, 08:40 PM #26
- Feb 2009
- Lodi, CA
- 1,126
Yeah, back in the day ..... just throw a rope around the truss, hang a come-a-long from it, pulled and installed engines with it all day long.
11-22-2009, 12:36 PM #27
- Dec 2007
- National City CA
- 1,086
11-22-2009, 05:07 PM #28
The reason . .
The reason for for the high cost of factory built gantry cranes beyond the obvious cost to built it yourself can be summed up in one word, "liability" . . .
Steve
Millermatic 251
Lincoln AC/DC "Tombstone"
Milwaulkee Grinder 4 1/2"
Clark Grinder 4 1/2"
11-22-2009, 06:31 PM #29
- Dec 2007
- National City CA
- 1,086
11-22-2009, 08:40 PM #30
- Mar 2009
- Michigan
- 137
lifting
Go to your local scrap yard and but the strangest beam you can find. Then go to Harbor Freight and buy a trolley and 1 ton chain fall for 100 bucks. O yea don’t forget the lifting straps. Then when it all falls down you can call china with your lawsuit. JUST KIDDING! Lifting heavy loads is not something to mess around with. In my rigging training I learned 2 things, NEVER stand under the load, and NEVER use anything that is branded with the make CHINA.
Miller Spectrum 875 Plasma Cutter
Miller Milermatic 135
Ridgid Drill Press
Ridgid Chop Saw
36" Metal Break
Harris Toarches
English Wheel
Ingersoll Rand, 18.1 cfm Compressor
30 gal. Sand Blaster
Planishing Hammer
150lb Anvil
10" Swing Logan Lathe
before load testing.
