Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
    Default Steel Beam for Garage
    I am planning on putting a steel beam in my garage to attach a chain hoist and trolley to it.
    It will not have any structural support of the garage and intended to be used for pulling some engines, and some other vehicle parts for repair and restoration. I am looking at getting a 1 ton chain hoist and trolley.
    My question to you is... What size beam do I need for a clear span of 12 feet?
    Aug 2006
    Raymore Missouri
    1,920
    Your local steel supplier can give you that info. Don't guess. Talk to an expert.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Oct 2007
    2,949
    Default "Beam Me Up, Scotty"
    Quote Originally Posted by shortgoroper View Post
    You can use an on-line calculator from the following website:
    www.engineersedge.com/beambending/beam2.html
    You need to know the following:
    moment of intertia of the cross section
    modulous of elasticity of the material
    distance from the center of the beam to the outer edge
    Hope this helps
    Dave
    "Bonne journe'e mes amis"
    Feb 2009
    Lodi, CA
    1,305
    Your local steel supplier, unlike what monte thinks, is not noted for engineers. They simply stock, and supply steel. They deliver, whatever size and length of steel you order, that's all.
    This calculation is fairly simple, look to Dave's links. Some of the oldtimers here (poke-poke), will have books, that specify what's needed. You have simply, a max xxxx pound load, that may be centered between two supports, xx feet apart.
    I would be more concerned with, how you plan to hold up (not really a big deal), and how you plan to stabilize the load (both ways).
    Feb 2009
    Island Falls Maine
    562
    whatever you got out back on the scrap pile will work.
    The beam will be set on the exterior wall (cinder block). then across to a perpendicular wooden beam. The steel I beam will then be fastened to that cross wooden beam, and the top of the cinderblock wall.
    That link you guys mentioned does not exist.. got some type of error on their web page.
    I will keep looking at that site though!
    Oct 2007
    2,949
    Default "High Beams"
    Try this:
    navigate through the website, and you'll find the calculators
    Los Angeles
    2,914
    Just find the Beam Deflection calculator once yer in the sire.
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Aug 2006
    Raymore Missouri
    1,920
    Your local steel supplier should have this info of what I beams will carry per span with deflection etc. If not, they should. They do not need to be engineers. They should have charts on their steel from their suppliers.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    southern California
    1,783
    I would build it as a self-supporting gantry crane. Otherwise, you also need to know how much weight the wood beam and cinder block wall will support. Finding the needed size for the cross I-beam is easy compared to finding what the wood beam and wall will support.
    Google 'gantry crane' and see how they're made.
    Millermatic350P/Python, MillermaticReach/Q300
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    ThermalArc 185ACDC, Dynaflux Tig'r, CK-20
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
