    Sep 2009
    6
    Default Two new projects
    Wanted to post some pictures of the latest projects for my home shop.
    The welding cart holds my Diversion 165, Millermatic 211 and an old Miller stick machine. I added some tubes for tig rod as well as wiring all three units to a central box resulting in one power lead for all three.
    The table turned out to be a little more complicated than I originally planned, but the intent was to make it as compact as possible when not in use. The top is 30 X 38. Started out as 3/4" thick. Was then stress relieved and blanchard ground to .010 flat over all. Enables it to be used for some fairly precision work. Added a pattern of 1/2" threaded holes for clamping. Also added four drawers for supply storage. The two collapsing legs make it real stable when extended, but allow it to be very compact when retracted.
    Apr 2008
    dallas,tx
    204
    very nice, what did the blanchard grinding run you?. Any plans to plug the holes when not in use to keep them clean?
    Miller 350P
    Miller Econotig
    Milwaukee Dry saw
    Evolution Dry saw (for sale)
    Scotchman 350 cold saw
    7x12 bandsaw
    1910 ATW 14 x 72 lathe
    fridge full of adult beverages
    Sirius radio
    www.snpequipment.com
    callouses and burns a plenty
    Central Florida
    195
    pretty nice table. can you leave the table angle a bit? may make it nice for sit down work.
    Andy
    Diversion 165
    MillerMatic 211
    Enco mill/drill with DRO and 8" Palmgren rotary table
    6" Atlas Lathe
    Husky 3.2 hp 60 gallon air compressor
    2 Milwaukee portabands
    14" Dewalt chop saw
    Island Falls Maine
    562
    handy looks good.
    Sep 2009
    6
    The total cost of the plate including stress relieving and grinding was $400.
    The tapped holes in the plate are counter bored and I've made aluminum plugs that slip in to protect the threads.
    Jan 2009
    Ohio
    191
    Thumbs up Welding Cart
    Hey Jime 46,
    The cart looks very nice. Always nice to roll it all to the job. Makes building things fun when you have it all set up right. Nice job again.
    Vernon
