Thread: Oops!
    Dec 2008
    Arizona
    812
    Angry Oops!
    I screwed up, but luckily not on a weld. I undermixed the hardner in some body filler, 2nd pass, and now have a mess. I scraped up what I could, but don't want to put down another coat until I'm sure it's all off, don't want to end up with uncured filler under my paint. Sanding resulted in a bigger mess.
    What can remove the uncured filler?
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Sep 2008
    Toronto, CAN
    54
    Default clean off uncured filler
    Acetone maybe?
    Trailblazer 325 EFI
    SVI 300i cvcc
    Mig 4HD & Mig 2E wire feeders
    Ultra-Pulse 300i Pendant
    EAS-IV Electronic Arc Starter and Plumbing Box
    Powermax1000 G3 Series
    AC-225 Arc Welder
    Mpls, MN
    1,790
    Unless you really went low, the stuff should eventually cure. Some of the fiberglass surface curing agents might work too. The filler you used was polyester right?
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    West Farmington, OH
    746
    A Stanley shur-form file or as some call them a micro plane should get it off, of course you'll get some of the first coat as well but you'll be sure to get it all off. Most of the time though if it's just a little bit the next coat if mixed properly will cure what little remains. You can also use the surface hardner for fiberglass as mentioned before.
    Blondie (Owner C & S Automotive)
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
    Dec 2008
    Arizona
    812
    Quote Originally Posted by Fishy Jim View Post
    It's been on there for 2 days, still soft. Yes, polyester, Marstons
    Quote Originally Posted by TerryL View Post
    Acetone maybe?
    I'll try that
    Quote Originally Posted by Blondie_486 View Post
    Not enough on there for a surform file, total thickness is less than 1/16".
    130XP MIG
    Spectrum 375
    Mpls, MN
    1,790
    1/16" is pretty thin. Try the surface hardener and maybe a little heat from a hair dryer or heat gun (just don't go too crazy).
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    When using any filler keep it as thin as possible 1/8 inch thick max.
    If you need more than that your metal work underneath is not good enough .
    Work your metal out closer to the shape you need.
    But back to your ?
    Lacquer thinner or acetone will remove it.
    I prefer lacquer thinner not as bad a acetone.
    After its scraped with a cheese greater
    Make sure all the chemical has out gased before appling your next coat or you will get solvent poping under your primer
    Rich
    Love the power of Blue
    Sync 200
    Lots of Tools!
    Mpls, MN
    1,790
    Quote Originally Posted by Fortyfords View Post
    Rich
    The only bondo work I've ever done was grafting on plastic parts to metal ones. 1/4" and thicker in some cases - never had cracks even in the dead of winter.
    It's not always about pounding tin.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    Jul 2007
    241
    After you clean the bulk of it off with laquer thinner,dont forget to rescuff the area you are applying it to with 80 grit, the scratchesleft behind is where the bondo gets its adhesion. BTW most body fillers cure much better at 60 degrees F and above.Mike
