At LWS the man said that I should use C8 instead of C10 Pulse Mode on steel. All he said it worked better. That is all I could get out of him. I like to know what the diffrence be tween the two gasses are. Other than 2 percent diffrence in Co2. Witch one performs better. On the weld chart it states C10.
Any help on this question.
Thank you
Results 1 to 10 of 13
11-11-2009, 08:52 PM #1
- Dec 2008
- Omaha, Nebraska USA
- 44
Witch gas is better for Pulse Mig Mode (steel)
11-11-2009, 09:25 PM #2
- Nov 2009
- 6
Gases for pulsed mode
There are many different gas mixes that can be used for pulsed mode. Assuming that you are welding steel, gases must contain at least 80% Argon to get the wire into the spray mode well.
You can practice with this without equipment that is too specialized by raising the wire feed speed and voltage (using a gas mix with at least 80% argon). Most of use have gotten used to the short circuit transfer mode and are accustomed to that "frying bacon" sound. As you increase the wire feed speed and voltage you will start to see the arc go from short circuit to spray transfer mode. This threashold depends on wire size, so to test you may want to use a small wire size like .030 or .035. As you get into the spray mode well, the transfer process will go to a directed stream of small molten droplets of metal. That frying bacon sound will go away, and the arc will be very hot with little or no spatter.
You can test different gases using this method to see what runs the best if you have time. The best gas for spray welding will also work well for pulsed spray welding.
I would recommend that you try some argon CO2 mixes like 92% argon /8 CO2 and maybe some argon oxygen mixes to see what is best. 98% argon 2% oxygen is a good mix that would work well too.
Keep in mind that the pulsed spray process is designed to give more controllability to the spray process. The spray process will give very deep penetration and very fast travel speed, but it only works well for flat or horizontal fillet welds (standard tee joints). The pulsed spray process pulses from short circuit to spray so that you tune in the process for specific applications.
Maybe this will help.
11-12-2009, 05:29 AM #3
- Nov 2009
- Wooster, OH
- 18
It would be very difficult to notice a difference between the two. CO2 is cheaper than Argon, so the more Argon you get the more you pay. If all you are doing is short arc (frying bacon sound) then use 75/25 mix, it will be easier on your wallet.
Some distributors carry 90-10 mixes and some carry 92-8, maybe someone that is in the gas business will answer. Hopefully it's a legitiment reason other than they can charge 2% more for the extra Argon in it.
11-12-2009, 08:25 AM #4
- Dec 2007
- southern California
- 1,783
Which machine are you referring to?
The Millermatic 350P's pulse program is designed to work best on 90/10 for mild steel with solid wire. Miller tech support told me that when they tested the 350P, that is the gas it worked best on. They said they're second choice is 95/5.
If you're talking about the Optima pulser, it is designed to run on 95/5 for mild steel with solid wire.
I believe the Invision and XMT 350 MPa machines are also designed to run on 95/5 for mild steel with solid wire, but you would have to check the manuals to be sure.Millermatic350P/Python, MillermaticReach/Q300
Millermatic175
MillermaticPassport/Q300
HTP MIG200
PowCon 300SM, MK Cobramatic
DialarcHF, Radiator-1
Hypertherm PowerMax 380
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-LoadNGo utility bed
-Bobcat 250NT
-PassportPlus/Q300
-XMT304/Optima/Spoolmatic15A
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
11-12-2009, 11:22 AM #5
Since weldertim mentioned it I'll post up a cool video I found
http://www.youtube.com/watch?v=7AZXG5WVw6EEd Conley
11-12-2009, 04:50 PM #6
- Dec 2008
- 44
The machine I have is 350p on the weld chart it uses 90% argon 10% Co2
Thanks for the in put on this topic
11-12-2009, 06:09 PM #7
- Dec 2007
- 1,783
There are a couple of us here who have 350P's. Post up if you have any issues with yours.
Millermatic175
HTP MIG200
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-Bobcat 250NT
-PassportPlus/Q300
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
11-12-2009, 06:57 PM #8
- Dec 2008
- 44
Are ther problems with these machines I have had problems with bad starts and burn back.
11-12-2009, 06:58 PM #9
- Feb 2007
- West Farmington, OH
- 746
I use either 90/10 or 95/5 for spray arc. I worked at a place that had 95/5 piped throughout the plant for steel welding it really makes a difference in the welds, they wash (wet) in so nicely with the higher argon content even in short arc mode. Normally I weld with 80/20 and get good results from my Millermatic 35 but it's too light of a machine for any spray arc welding with that mixture, I haven't tried 90/10 or 95/5 with it yet.
Try a small bottle of 90/10 and see what happens. Most welding suppliers will let you take out a small bottle of gas to try out if you're a regular customer. If you're not happy with the results take it back and try a higher argon content mix.Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
11-12-2009, 07:34 PM #10
- Dec 2007
- 1,783
I haven't had a lick of trouble with mine and I worked in a shop that had 3 of them we used in high volume production too and we only had minor problems with one of them with the push-pull gun. As much as we used those machines, I'd rate their reliability record as excellent.
There is a run-in speed adjustment for the start you can play with to help with that. In the aluminum pulse program there is also a hot-start adjustment you can use.
One note, don't start with a long stick-out length. Start with your stick-out length equal to your stick-out length while welding. It will start rough, spattery and cold if you have too much wire out at the start.
I haven't had any problems with burn-back on mine. Maybe try reducing your arc-length adjustment or try the crater-fill feature.Millermatic350P/Python, MillermaticReach/Q300
Millermatic175
HTP MIG200
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-Bobcat 250NT
-PassportPlus/Q300
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
