I am welding up a new welding table and not sure the best way to go about it.I need to weld some 2" square tube to some 3/4" plate.The square tube has rounded corners.Should I stick weld this or Tig weld it.I don't have a mig so that won't work for me.I have never welded a joint like that and don't want to make a mess by going about it the wrong way.The wall thickness is 1/4".This is a fillet weld and I have done them at my night course but never with that rounded corner just want to make sure I do it right.
Results 1 to 10 of 33
Thread: What would a pro do?
11-08-2009, 08:05 PM #1
Member
- Sep 2008
- Crediton Ontario Canada
- 93
Harris welding torch
Harris Cutting torch propane
Syncrowave 200
Mastercraft 4.5 grinder
20 ton press
Milwaukee 14" Dry Cut Machine
Miller Digital Elite (Luckys Speed Shop)
3/4" Welding Table
11-08-2009, 09:09 PM #2
- Feb 2007
- West Farmington, OH
- 746
I'd stick weld it. If you're not that skilled at stick try using a 7024 or 7028 rod they weld nice but don't run out of position so you'll have to turn the table upside down to do it. Myself I'd use a 7018 rod but I've been burning them for a long time now.
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
11-08-2009, 09:33 PM #3
- Dec 2007
- southern California
- 1,783
I would stick weld it. Use 6010 or 6011 for the first pass and 7018 for the cover. If you want a full penetration joint, grind a 45 degree bevel around the edge of the tube, put in a root pass with 6010 or 6011, then a second pass over that with same, then fill/cover with 7018.
Millermatic350P/Python, MillermaticReach/Q300
Millermatic175
MillermaticPassport/Q300
HTP MIG200
PowCon 300SM, MK Cobramatic
ThermalArc 185ACDC, Dynaflux Tig'r, CK-20
DialarcHF, Radiator-1
Hypertherm PowerMax 380
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-LoadNGo utility bed
-Bobcat 250NT
-PassportPlus/Q300
-XMT304/Optima/Spoolmatic15A
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
11-08-2009, 10:05 PM #4
- May 2008
- Troy, MI
- 273
Some people prefer to bolt the top to the legs for welding tables to minimize any chance of warpage. You could weld a frame out of 2" x 2" tubing then weld gussets in the four corners. You could bolt if from the bottom through the gussets and into tapped holes in the 3/4" table top. Make sure that you overlap the top so you have room for clamps.
PS. I like your choice of 3/4" for the top. I have had trouble with warpage on a table that had a 1/4" top.
Don
Miller Thunderbolt
Smith Oxyacetylene Torch
Miller Dynasty 200DX
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
11-08-2009, 10:27 PM #5
- Feb 2008
- Guam
- 177
I second the bolt method or about a dozen 1'' tacks with 1/8'' 6011, at least 2'' on the over hang, I went 4'' and glad I did.
11-09-2009, 05:29 PM #6
- Feb 2005
- N.E. SD
- 1,366
Just skip weld it with stick. 6010,7018, whatever you have.
Just be careful about heat, and keep checking for flatness.
But I wouldn't think that you will have much trouble welding 2x2 tubing to 3/4 plate
Jeff
11-09-2009, 05:34 PM #7
What size is the 3/4" Plate ( L X W ) ?
Good Advice by all above !
............ Norm
- Weldcraft WP26FV Tig Torch setup.
- Arcair- K 4000 CAC.
- LN-25 Wire Feeder
- Miller Econo Twin AC/DC High Freq.
- Lincoln Power Mig 180C
- Spoolgun.
- Horizontal Steel Band Saw
- DeWalt Chop Saw .
11-09-2009, 07:40 PM #8
Member
- Sep 2008
- 93
Thanks everyone!Sounds like being worried about the rounded edge is worry for nothing.
Norm the 3/4" plate is 33"x48" and the 2"x2" frame is 25" x 40" leaveing a 4" overhang.Harris welding torch
Syncrowave 200
20 ton press
3/4" Welding Table
11-10-2009, 06:48 AM #9
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
11-10-2009, 07:04 AM #10
- Sep 2005
- 4,247
Just cause you can don't mean you got to weld the snot out of everything. You don't need root/cover, any weld will do and it doesn't take much to hold a table together. Gussets do not help a bench much, they don't bend at the corners but across the middle span but that wont be an issue with 3/4 plate.
He is already saying the tubing is "rounded corner" so no shaping is needed.
