Results 1 to 10 of 13
    Oct 2008
    Melbourne, Florida
    31
    Default Used Scuba tanks
    I have 3 old out of date / vip steel scuba tanks that I was wondering what I could use them for. What type of project I could build. I know I could build a large bell, but does anyone have any other ideas?
    Also, if anyone near me that would like one, I would let them have one (local pick-up only) for free.
    David
    Learn new things every day.
    You only have so many days.
    Century Mig.
    Craftsman stick.
    Miller Diversion 165 Tig
    Hobart Plasma
    HF DC Tig
    1-O/A out fit
    143
    potato gun air supply tank?
    Jan 2009
    Mansfield, La
    83
    Default Air tank...
    Change out the fittings and use as tank for on board air compressor tank on off road truck, buggy? Could have lots of air space to run a set of train horns that a lot of people are going nuts over. Cut them down and make butane burners for fish cookers. That's what I come up with off the top of my head.
    Bobcat 225
    Radnor o/a
    An assortment of
    other tools and toys.
    The one DANO!
    Oct 2008
    Melbourne, Florida
    31
    Default Scuba tanks
    Thanks Bigiron,
    I can see making a compressed air bottle, but I don't understand how to cut it down to make a butane burner?
    David
    Century Mig.
    Craftsman stick.
    Hobart Plasma
    HF DC Tig
    1-O/A out fit
    Feb 2008
    Western NY State
    41
    Default Used Scuba Tanks
    Oxygen cylinders make pretty good bells if you cut the bottom off and put a hanger on the inlet. There is alot of steel in them that I think helps the ring. I have cut some fire extinguishers but they are pretty thin. Scuba tanks??
    Bill
    Miller Mig 130XP
    Linde VI206 W/Mig
    Miller Econotig
    L Tec Plasma PCM32i
    Pneumtic Forging Hammer 75#
    Mechanical Forging Hammer 65#
    Propane Forge
    Makita Chop Saw
    Bader 72" Belt Grinder
    Bader Knockoff 72" Belt Grinder
    Milwaukee Portoband
    Jan 2009
    Mansfield, La
    83
    Default ...
    Quote Originally Posted by david myers View Post
    Thanks Bigiron,
    David
    Pretty simple really. If they are steel, then cut a section out about six to eight inches long. Use round stock for legs. Either bend those to form a foot and come back up somewhere and weld to itself, or just use a piece of flat bar to make a foot. Come off the top, up and out at an angle about six to eight inches with three pieces of round stock spaced around the cylinder, and then bend a piece of round or square into a circle and weld to that. That's the platform the pot sits on over the burner. Use various parts purchased to repair a butane burner at the hardware store or some such to plumb in the butane line. Probably pick that stuff up in Home Depot by the butane bar b que pit section and or in the plumbing or heating section. Look up some burners on the internet to get a better picture of what I am trying to describe, or maybe someone can describe it better than me. The legs can be any where from twelve inches or longer. Your choice on length. You can use square tubing as well for legs. Once you see one at the hardware store or walmart or somewhere that carries them I'm sure you will see what I am talking about. Crawfish cooker will probably turn up similar results in a search engine on the net. Good luck.
    Bobcat 225
    Radnor o/a
    An assortment of
    The one DANO!
    PA
    286
    David,
    This artist make lots of interesting sculptures including bells out of scuba tanks, fire extinguishers and other metal parts.
    http://www.kiderafineart.com/ed_homepage.html
    I've seen people cut designs and scenes into a large diameter metal pipe to make a fire ring. Another use was to make a tall desk lamp out of a fire extinguisher body. The artist used a plasma cutter to cut animal designs in the wall. Then he put a couple of small 12 volt halogen lamps inside and projected the designs on the corner of the room where the lamp was placed.
    good luck
    Central Florida
    195
    wish i had the stuff to play around with one i'm not to far from you david. Good luck with them though
    Andy
    Diversion 165
    MillerMatic 211
    Enco mill/drill with DRO and 8" Palmgren rotary table
    6" Atlas Lathe
    Husky 3.2 hp 60 gallon air compressor
    2 Milwaukee portabands
    14" Dewalt chop saw
    Oct 2008
    Melbourne, Florida
    31
    Default Scuba tanks
    andyman,
    If you are close by come by and I will give you one.
    David
    Century Mig.
    Craftsman stick.
    Hobart Plasma
    HF DC Tig
    1-O/A out fit
    Central Florida
    195
    there isn't much i could do with it but put a few fittings on it and make an air tank out of it. i dont have a set of torches or a plasma cutter to cut on it or anything. i may get it for an air tank though.
    Andy
    Diversion 165
    MillerMatic 211
    6" Atlas Lathe
    14" Dewalt chop saw
