    Nov 2009
    South Alabama
    255
    Lightbulb MM211 custom welding cart
    This is the welding cart I built for my MM211 welder. I wanted more than just the plain cart avalible for it that has no storage. A welder is just the start, then you make 50 trips to get everything you need. I made places to carry the spoolgun in its box, a small tackel box to carry extra tips and parts, an aluminimum box for gloves, wire, pliers, wrench, wire brush, and other stuff. The front has a holder to roll the cables up on and a sleave to hold the gun while working, also a holder for mig pliers. The machine is bolted to the cart and there is a storage bin between the welder and bottles for the mig whip when using the spool gun. The welder is set to one side making a small ledge to give a work area to set tools and wire rolls on while changing spools. There is a capability to hold 3 bottles and they are secured from moving with 2 ratchet straps. There is a lifting ring on top so the whole rig can be lifted into a truck or trailer ready to weld. A few strategic cross bars to attach tie downs to and she is ready to go.
    "The only source of knowledge is experience." Albert Einstein
    3,671
    Nice job. Switch your spoolgun over to the regular mig gun tip and you can get rid of 1/2 of your tips and the expense of those little tips...Bob
    southern California
    1,783
    Very nice! I like the 4-gang j-box on the front of the cart too! All you need is a couple hooks to hang your grinders and hood on and you'll have the complete mobile work station!
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Raymore Missouri
    1,910
    Nice job.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Jul 2008
    Delhi, Ontario:
    1,950
    Nice job, my only suggestion would be to raise the gun holder up some.
    A little too low for me !
    All in All, nice job though !!
    ................... Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
    Island Falls Maine
    562
    at least it holds everything togather.
