Results 1 to 10 of 19
    Default Truck Bed Drawer Slide
    My buddy does flooring for a living and traded his van in on a pickup. After a couple months using a tonneau cover, we finally got him a camper shell last night. Great, except Phil is a large man and I don't see him easily getting stuff out of the front of the bed as the side windows on the camper are vent windows. I have been looking around at the in bed sliding drawers and was wondering if anyone has made one, or has any ideas as far as making the slides. It is only a short bed, but it would be nice if he could also use the table as a work surface when fully extended. Here is a link to one being installed. Anyone have any ideas, or have built one before?
    http://www.fourwheeler.com/techartic...eck/index.html
    2003 Dodge 3500 Cummins
    25' Hydraulic Tilt Lowboy Gooseneck
    1997 Corvette 6 Speed
    Harley Hardtail Bobber
    Millermatic 251 with 30A spoolgun
    Syncrowave 180SD
    Cut40 Plasma Cutter
    Sep 2007
    Medford MA
    542
    Quote Originally Posted by Joey-D View Post
    Hi
    I recall that there was a discussion about exactly what you
    are talking about either on this forum or on the Hobart one
    (http://www.hobartwelders.com). Some quality time with the
    search tool on either site ought to get you what you're looking
    for.
    Good luck
    frank
    thanks, I'll check it out. Only ever been on millerwelds....
    Syncrowave 180SD
    Cut40 Plasma Cutter
    I search here before I posted and searched the hobart site and still haven't found anything. Searched pirate4x4 and google to. Only home made ones I found were wooden.
    Syncrowave 180SD
    Cut40 Plasma Cutter
    Aug 2008
    Thetford VT
    64
    Take at look at these, We have them in our fire/rescue trucks. They work well.
    You can get a idea of how they are built.
    www.slide-master.com
    Chad
    Trailblazer 302
    Suitcase 12 RC
    S22P-12 Feeder
    HF-251-2
    Spoolmatic 30A
    Maxstar 200 DX
    Shopmaster 300
    S-22A Feeder
    Coolmate 3
    Trailblazer 250G
    Lodi, CA
    1,302
    Expand your search a little bit, or maybe somebody can remember one of these threads ..... quite a few guys posted up pics and builds of slides, they mounted SA-200 Lincolns on, 1400# or so. Slide the machine out for full access, for servicing. Easily adaptable for what you want to do.
    Lodi, CA
    1,302
    Just look at your kitchen drawers; do something basically the same, using angle iron frame bolted to the bed, formed or welded C-section for the sliding part, and cam followers for the rollers.
    Cargobed makes a nice product. Yes it works similar to a drawer roller. My welder,cables,oxygen/acetylene bottles (approx 2000lbs) are mounted on my cargobed,on my welding rig.
    southern California
    1,783
    I have a sliding frame I modified/built for my Bobcat so it can ride forward in the utility body and slide back so I can reach the controls without climbing into the truckbed, also so it can have more breathing room, since I have alot of other stuff mounted in the bed near the welder.
    I ran accross an ad on Craig's List, the guy was selling a used Bed Slide unit for mini trucks for $100. Couldn't pass up the deal. I brought it home, took it all apart and started chopping it up. I skinnied up the width to 18" to match the width of the Bobcat and cut down the length a little under 6 feet. I reinforced the top and bottom frames and built a second support/mounting frame under the bottom frame.
    The unit bolts into the bed floor and the Bobcat can slide up to 3 feet to the rear of the truck bed. This puts the face of the Bobcat about over the center of the tailgate when the tailgate is down. It works very well. Only thing is, the truck must be reasonably level to use it or it is either very difficult to slide it out, or very difficult slide it back in since the Bobcat and top frame are heavy.
    In this pic the Bobcat is slide all the way into the truck bed.
    In these pics, the Bobcat is slide most of the way out. It can slide about one more foot out, where it reaches the last safety stop I made for it so it won't slide all the way out onto the ground. There are 2 stop positions it can slide to before the final stop and stay in that position untill the handle is turned to disengage the stop pin. The loops on the front of the frame keep the top frame from being able to jump up off the bottom frame when the Bobcat is slid all the way in. The truck can only be driven safely with the frame slid all the way in, or risk the frames disconnecting on a big bump.
    Sorry, I don't have any pics of the frame as I was building it or before I put the Bobcat on it. I should have taken some.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    southern California
    1,783
    The utility body on my truck also has a large 4'x8' storage drawer under the floor. I love this drawer! It is so useful and really is main reason I wanted this body.
    In these pics, the drawer is slid about 2/3 of the way out. The drawer is about 8" deep. I took these pics a couple years ago and have since packed the drawer with alot more leads, cords and hoses. I wish I had a second drawer on top of this one!
    Millermatic175
    HTP MIG200
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -Bobcat 250NT
    -PassportPlus/Q300
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
