Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
  1. #31
    Jul 2008
    Portland, OR
    189
    Part of the wood storage solution is no longer a welding project and that's OK. I used what I have on hand...stout metal fence posts that were supporting raspberry plants.
    These will work great for off patio storage and I certainly did not re-invent the wheel with this solution
    I sure appreciate all of the responses and the time you guys spent thinking about MY PROBLEM. I'd do the same if I had something to offer.
    MillerMatic 140 Auto-Set
  2. #32
    Jun 2009
    greenfield new hampshire
    884
    Default balancing act
    i just whipped 1 together for my crap wood outside the shop, when you stack wood there is hardly any horizontal stress (unless mobile) i made mine from 1x1/8 angle and 6011.d it together, cheap, strong(enough), light, quick to make, its not pretty but holds a bunch of wood stacked in and around and on top of a 4x4x8 frame
  3. #33
    Nov 2005
    Toronto,ON
    22
    Not metalworking, but something I put together right next to the back door.
  4. #34
    Dec 2005
    San Diego, CA
    168
    Default My Wood Rack
    I have a 1 X 1 16ga sq tube fetish. This rack has a truss design on the bottom, it is 48in wide 36 tall. I load it with oak and it never even groans.
    Put some engineering into your designs guys.
    Frank
    (aka Fred)
    MM200 (antique and still cook'n)
    Lincoln 160 buzzzzzz box - left to live with a nice youngster
    Dynasty 300DX
    Spectrum 625
    Chevalier Knee Mill - Bridgeport clone you idiot.
    Homebuilt tube bender - with home made dies no less
    Delta Drill Press & Grinder collection
    Needed - a bigger shop to use the stuff
  5. #35
    2,913
    Quote Originally Posted by Fred Smith View Post
    Attachment 20094
    That doesn't look like 1"x1"
  6. #36
    Dec 2005
    San Diego, CA
    168
    Default trust me
    Yes it is 1 x 1 with 1.25 band along the top edges and the "feet".
    It's like Bubba Gump talking about the versatility of shrimp, 1 x 1 tube, you can bend it, miter it, weld.... good stuff
    I have some other projects made from it that are actually bigger, I'll get my posterior out to the garage and take some pictures to post.
    one is a pet food (catch all) cart and the other a bench for a radial arm saw, 2 tool boxes and a slew junk under it. And I didn't even get to shovel and poo scoop.
    Frank
    (aka Fred)
    Dynasty 300DX
    Spectrum 625
  7. #37
    2,913
    I thought it was sitting on the ground but I see now it is up on a table
  8. #38
    Feb 2010
    San Antonio, Texas
    Default wood storage rack
    First of all your idea is good.(don't worry about the drawing) The size and gage of the material is fine. What you do Need is to find yourself a better supplier for the material. In San Antono, Texas, 20 foot length of square tubing runs about $6.00.
    The price you are going to pay, would make about 12 racks at our price.
  9. #39
    Feb 2010
    Stony Plain, AB
    11
    A little off topic for a welded firewood rack but here is where I store my firewood. It's 10 X 12 X 8ft high. Will use most of it during an average winter. I also have a rack made of 2 X 4's closer to the house. it would be 8ft long about 14 inches deep and 6ft high.
