Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
    Jul 2008
    Portland, OR
    189
    Default building a firewood storage rack. questions
    I want to build a firewood rack and need to know what material dimensions would be acceptable. I don't have a fancy CAD program so I made a "sketch" in PhotoShop- go ahead and have a free chuckle. I hope I have given enough information to fetch an answer? I may choose to make a couple 4' wide units instead. This will probably end up being heavy if it's 7' wide?
    I refuse to buy a bolt together POS from Home Depot when I own MM140- even if it's $500 in labor.
    Is 1.5" x 1.5" square A513 tubing overkill or inadequate? What wall thickness will suffice? Am I WAY off base in materials selection?
    I got a rough idea of materials cost by getting an online quote from metalsdepot.com. Metals Supermarket will likely be my supplier and I haven't a clue about what they'll charge for this type of material- they're website is a bit shy of functional?
    A513 Steel Structural Square Tube 1-1/2 X 1-1/2 X 16GA (.065 wall) 48' = $93
    A513 Steel Structural Square Tube 1-1/2 X 1-1/2 X 14 GA (.083 wall) 48' = $118
    A513 Steel Structural Square Tube 1-1/2 X 1-1/2 X 11 GA (.120 wall) 48' = $136
    MillerMatic 140 Auto-Set
    3,651
    I would look for a metal supplier thats close...Bob
    Jul 2008
    Portland, OR
    189
    Metal Supermarkets is 17miles one-way and I am OK with that.
    Thanks.
    Indiana
    541
    Is this going outside? if so you may want to put something under the feet so it doesn't sink.
    Looks good. If outside are you going to cover it?
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Jul 2008
    Portland, OR
    189
    It's going outside. I'll probably add material to the legs so it dosen't dig into my concrete patio.
    It will be covered with a lightly customized blue tarp. I sew better than I weld.
    another top notch sketch... with skids added
    Jul 2008
    Portland, OR
    189
    Quote Originally Posted by tnjind View Post
    Forgot my manners. Thank You!
    May 2008
    Belle Plaine Iowa
    233
    Youre going to have a lot of weight 7 feet high with only a 14 inch footprint. To keep from having it fall over on the neighbors poodle, Id make it longer and not as tall. If youre dealing with a confined space bolt it to the garage wall.
    Miller AC/DC Thunderbolt 225
    Miller 180 w/Autoset
    Old cutting torch on LPG
    Jul 2008
    Portland, OR
    189
    Quote Originally Posted by Flyingpig View Post
    Thank You. a 14" footprint is very skimpy, re-think due. As of this moment it'll be 5'high and 7' wide. I'll increase the feet to 18" perhaps though it will create a trip hazard, at least for me.
    Mar 2009
    234
    As a point of reference, Metals Depot's prices are ridiculous.
    1"x1"x24' 16ga from them is $23. My price for a 20' length in Los Angeles (where things ain't exactly cheap) is only $6.
    Sep 2007
    Medford MA
    524
    Quote Originally Posted by Johnny View Post
    either you won the lottery or have goat pictures of the local m.s. manager
    seriously -- for any non-trivial amount of material, find a steel service
    center/dealer/...er. the price difference is major.
    s to your design -- i built one about the same -- except that it was not
    as long and i did not put the stretchers along the top. it works well.
    you _might_ want to consider putting only 1 such stretcher along the top.
    it would make it easier to load/unload the rack.
    good luck
    post pictures.
    frank
