Results 1 to 2 of 2
    Jan 2009
    Default engine stand help
    i want to build an engine stand for a flathead v8 that i can run the engine on.i need ideas and better yet plans
    3,928
    Just build a rectangle frame a little bigger than the footprint of the engine and add the mounts you need to hold the motor so it does't twist around when you run it...Bob
