Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: Army tank welds
    arkansas
    781
    here is that link. it is a little scary though. so watch in dismay as they find another machine to replace the common working man
    http://www.ctc.com/learnaboutctc/FSW_proj.cfm
    welder_one
    www.sicfabrications.com
    Vancouver BC Canada
    605
    The last time I saw anything on Friction welding was about ten years ago at least. One of the aircraft manufacturers(boeing??) was putting it to use in the contruciton of 747's. They were smearing large sheets of aluminum together in order to make wing sheathing and fuselage sheathing. I thought it was pretty cool how they could join two sheets without using any heat.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Ocean City, Maryland
    951
    Awesome link welder_one. I see the Marines new amtrac is welded with that process, really cool, thanks
    Scott
    HMW [Heavy Metal welding]
    Hopkins, MN
    557
    Talking
    It's also used to weld the frame of the Ford GT 500. Why's depleted urainium so nasty?
    Tennessee this week, Wyoming next week.
    49
    Quote Originally Posted by Anti-GMAW View Post
    Good question. I think it's because of the word radioactive.
    Uranium is a naturally occuring substance. Outside of Golden Colorado are hillsides that show the marks of the old uranium mines that have been played out and (purposely) collapsed.
    The tailings are still there.
    DU is only 60% as 'radioactive' as those tailings. They don't call it 'depleted' for no treason. People hike and walk their dogs over uranium every day.
    Hopkins, MN
    557
    Talking
    U-238 (depleted uranium) is just fine to handle. It is dangerous in the sense that it is a heavy metal and is a TOXIC substance. If you had enough of it enter your blood stream or resperatory system then you might want to seek medical help ASAP! But other then that it's just metal. It has the same hazards as lead nothing more. U-235 however is unstable and highly radioactive. The reason U-238 is used for armor and armor peircing amunition is because it's heavier aand denser than lead.
    Vancouver BC Canada
    605
    If you shoot a D/U tipped round it will catch fire as it leaves the barrel of your rifle or big gun or why. It will also explode on impact sending Uranium dust everywhere.. It IS dangerous no matter how you slice the pie. I'll have to go look for the link I found and post it here.
    Its a wild vid to watch...
    Syncro200
    Spectrum 625
    O/A
    54" laminator
    little dog
    arkansas
    781
    Quote Originally Posted by SignWave View Post
    are you asking what makes the round glow as it is shot? on crew service weapons, like the .50 cal machine gun, there are tracer rounds that light up when traveling down range. these rounds are capped with phosphorous. usually it is every fifth round that is a tracer, so that the soldier can see where his aim is at night.
    welder_one
    Vancouver BC Canada
    605
    no no no . they're not tracers. Serioously, Let me find the link... I'll be back
    these things ae really scary..
    Syncro200
    Spectrum 625
    O/A
    54" laminator
    little dog
    Vancouver BC Canada
    605
    Okay maybe you're right W1. At least you've got me thinking but have a look at this :http://www.youtube.com/watch?v=wgrzGslrYQc
    I know that this choppers gun can spit em' out mucho pronto...so maybe that is tracerf ire that I saw, but.... I know what I know.. D/U will explode on impact.
    Syncro200
    Spectrum 625
    O/A
    54" laminator
    little dog
