Well, I was watching some show called incredible machines and they did a peice on military tanks. Im not much of a military buff so the name of the tank eludes me. Suffice it to say that it is the US military's cats ***, top of the heap tank and it has over a half ton of weldments in its construction.. thats like a 100 miles of weld or something dumb like that...
Todays peice of useless information- no charge.
Results 1 to 10 of 42
Thread: Army tank welds
10-09-2007, 12:21 AM #1
Army tank welds
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
10-09-2007, 12:29 AM #2
- Jan 2007
- Montana, USA
- 201
10-09-2007, 04:37 AM #3
- Oct 2006
- 642
10-09-2007, 04:41 AM #4
that sir, would be the M-1 Abrahms
10-09-2007, 08:44 AM #5
M1, top of the heap when it comes to main battle tanks. Marines and Army both use it.
That was a cool show that showed them rebuilding them, Like new when done and saves a ton of money
Scott
HMW [Heavy Metal welding]
10-09-2007, 09:00 AM #6
Syncro200
Spectrum 625
O/A
54" laminator
little dog
10-09-2007, 09:04 AM #7
I think that some tanks are also covered in D/U (depleted Uranium). Its really nasty stuff , but when they are hit by gun fire, W.H.Y. the energy is absorbed and dissipated. I saw some army training film on how the repair battle damaged D/U armor. Nasty,Nasty stuff.
Do a YouTube search on D/U. Not sure you'll like what you see though...kinda shook me a bit.Will it weld? I loooove electricity!
Syncro200
Spectrum 625
O/A
54" laminator
little dog
10-09-2007, 09:20 AM #8
Syncro200
Spectrum 625
O/A
54" laminator
little dog
10-09-2007, 06:31 PM #9
Man, I thought that photo was a Locomotive's Headlight coming out of a tunnel......I believe they make the Abrams in Lima Ohio, I used to see them being freighted by Rail when I lived in Cleveland in the 80's. Paul
More Spark Today Please
10-09-2007, 07:39 PM #10
the armor plating is several layers thick. thinner layers to make one big layer. there is even aluminum in the layers. they use friction stir welding to weld the skirting and now setting up machines to weld the frames now. even researching making trailers with it. i saw a link to a video with friction welding, if i can find it again, i will post it.
