    hillsboro,OR
    45
    Default tungsten getting blue ?
    ok so after about a week of not tiging I went out to use my sycrowave 200 and now I am geting a blue color on my tungsten enyone know what going on this has never happened.
    Millermatic 135
    Syncrowave 200 with coolmate 3
    Hypertherm powermax 30
    were I am when I am home
    http://i21.photobucket.com/albums/b2...5/IMG_7413.jpg
    Vancouver BC Canada
    605
    I know that when I get my tungs too hot they go blue/black. if hteir isnt sufficient post flow they will go funny too.
    How long have you had your 200? Mines not working right.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    hillsboro,OR
    45
    about a year
    Millermatic 135
    24
    Quote Originally Posted by SignWave View Post
    ive had mine for about 4 months now and it seemsfine whats wrong with yours????
    Vancouver BC Canada
    605
    Check out this thread:http://www.millerwelds.com/education...ead.php?t=1912
    There are a few of my ranting here.
    Being fairly new to the machine and no prior friggin tiggin' experience, Im not sure what is and isnt correct function BUT I do know what isnt workin properly and stated in the above linked thread.
    Sorry about the Hijak.
    Back to topic about blue tung... Soemtimes eating blueberries give me a blue tung...
    Syncro200
    Spectrum 625
    O/A
    54" laminator
    little dog
    Vero Beach, fl.
    761
    Chris, the problem you are seeing can be one or all of three things, first is heat too high, second is improper shielding gas or flow rate and third is tungsten not sharp enough. Dave
    Ocean City, Maryland
    951
    Mine are sometimes like that but i just chalked it up to running to much heat on to small an electrode. Especially on aluminum when really cranking it hard. Didn't seem to hurt welds though. I have the older SW180 at home and it has worked great, lots of time on it with no issues. Doesn't have pulse though.
    Scott
    HMW [Heavy Metal welding]
    May 2007
    729
    Chris,
    What you are seeing is oxidization and contamination of the Tungsten. Try increasing your post flow time. The post flow does two things: in addition to shielding the deposited metal from atmospheric contamination until it "freezes", it also cools the Tungsten down as well as keeps atmospheric air away from it until it too is non-reactive.
    Later,
    Jason
    Lake of the Ozarks MO
    3,446
    I wouldn't waste one second of my life worrying about it.
