Results 11 to 20 of 24
    Aug 2009
    Phoenix,Az
    25
    Thumbs up band saw blade welding
    Hey out there-I weld them all the time-I tig weld them , very low power, like 10A and I use 1/32 mild steel filler. I made an aluminum fixture and clamp both ends to it and there is a relief cut into the aluminum under the weld bead about 1/4 inch wide. After you weld it -grind it smooth both sides and you will have to anneal it with a torch around the welded area-heat it (it doesn't take much) till it looks straw to purple in color and you have it! With a little practice you can weld them from one side only -the annealing is critical-if it's not annealed-it will break-remember-GOOD WELD -- THEN ANNEAL- If you have to grind it again, then anneal it again. Good luck
    Jim
    May 2009
    Muskogee Oklahoma
    245
    Or, you could do what I did and buy a bandsaw blade welder. It's made by Stryco. Bought it at a auction for $20 and it paid for it's self a long time ago.
    Sep 2009
    19
    I make all of my own blades from large coils of stock. I have tig'd them before with some success, but the only good way to do them is silver soldering them. You must get the right silver solder though. Very high silver content. A small bit will go a L O N G way. I have a nice jig that holds the blade together and aligns the edges for a true blade.
    Grant
    Raymore Missouri
    1,920
    I agree. I slightly tapered each end to give an overlap of maybe a 1/4" inch and used silver solder(the good stuff) and the blade is still hanging in there and that was in 2007. No mig...no tig...just a propane torch, flux and solder.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    To add to monte, make sure you polish the ends to be welded with clean emery cloth and then apply soldering flux before joining the ends...
    2 Miller Dynasty 350's
    Miller Axcess 450
    Miller Syncrowave 350
    Miller XMT 350 CC/CV
    2 Miller XMT 304's
    2 Miller CP250-TS's
    Lincoln Power MIG 300 with
    Cobra Max push-pull gun
    Lincoln WP 250 G9 PRO
    Mar 2009
    Hazelwood Mo USA
    462
    Quote Originally Posted by jackalope View Post
    Grant
    That is good to know, I never considered silvering it.........
    mike sr
    Feb 2008
    893
    That's right.
    The goal is ductile.
    The blade isn't under a huge amount of tension, but boy does it flex many many times.
    Mar 2009
    NY
    103
    Call me crazy but I have used one of these: On repair of blade we would cut off previously heated metal.
    http://cgi.ebay.com/Dayton-6a489-bla...d=200327783943
    Default Thanks
    I took fatfabs advise and it worked fine. One blade was brand new and was to coarse to cut thin angle iron and broke right away and the other was broken out of the box. That is why I wanted to save them.
    I am back in business.
    Thanks Again,
    Steve
    Sep 2009
    south-central Pa
    11
    i know a guy that brazed a bandsaw together with oxy/ac. might wanna try that??
