Results 1 to 10 of 14
    Oct 2009
    16
    Default Some of my projects
    Seen here somewhere a guy asking about building a grain trailer. I end up building specialty trailers that can't be bought to fit our needs. Usually try to use something that can be adapted,or at least give a good starting point. This isn't a grain trailer,but you could start the same way. Rolled her out of the shop today.
    This one started life as a railroad container hauling frame. Since their containers are self supporting all they have for a trailer frame is a 4"x12" I-beam,with 1/4" flanges and a 3/16" web. Basically enough to connect the 5th wheel plate to the axles. But, you can buy them cheap. The axles are rated heavy enough,and the light frame makes a good jig for hanging steel. This was a 48'er,only needed a 40'.
    Sorry for the quality,snapped everything with the cellphone.
    more pics coming.....................................
    Oct 2009
    16
    some more,
    more coming..........
    Oct 2009
    16
    and more,
    Oct 2009
    16
    Tested everything out this afternoon.
    Oct 2009
    16
    This was a fun project in 100 degr. heat. Had to replace the cone on this mixing vatt. Since I had to manage this myself I constructed a small crane to help place the pieces. Also worked well to ride it around while welding the inside.
    Oct 2009
    16
    Oct 2009
    16
    Took about a week to finish it. Glad there were no leaks, I was half sick and went home early the last day.
    banning ca.
    135
    really nice, great job
    gary...
    Aug 2009
    Sun Valley, So. Ca.
    5
    Ah yes. It's the little things in life we do. You guys and your fabrication skills simply amaze the **** out of me.....
    very nice work...
    mike
    Island Falls Maine
    562
    I like the way your trailer turend out.
