    Feb 2006
    19
    Default flex pipe repair
    when I saw the exhaust was bad on one of the back hoes at work I didn`t think too much of it,just get a new one and be done with it.That was untill they came back with a price of over 500.00 dollars for a 4'' pipe with a small section of flex pipe in it.I was able to repair it with a small piece of 5'' exhaust that I cut open and wraped around the bad spot and clamped tight.After about a half hour of doing the tack,tack,tack thing it`s good as new and a boat load cheaper.
    Feb 2006
    springvale me
    89
    very nice i like the nice clean job on that
    S.W. Pennsylvania
    2,250
    The repair looks good , but over $500.00 for a new one, thats outragous. What make is it ? They must be selling their name, the money cant be just for material and labor. If it is for labor , that would be a great outfit to work for.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    Feb 2006
    19
    It`s on a Hitachi ex 450. some times it`s just nuts what they want for parts, but they know they got ya nobody else makes the parts and a person cant afford to have the machine down for too long because it`s not making money then.
    563
    Replacement parts for all of the brands of earth moving machines are outrages.Getting in good with your local excavating contrators will keep you busy repairing and refubishing there equipment,they seem to like to spend money on local guys to do there work if possible,OEM dealers are ridiculous in their pricing.
    Oahu, Hawaii
    2,469
    Looks a little more than just tack,tack tack!!! WOW! NICE JOB!!!!!
    I'm not late...
    I'm just on Hawaiian Time
