Results 21 to 30 of 31
Thread: water tank
  1. #21
    Indiana
    541
    Wow CW,
    Good work, what was the second tank for? size?
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
  2. #22
    Definitely use 1/4" 6061 plate, NO smaller. I would also use 3 baffles. Weld it with 1/8" 4043 filler rod.
    -Kevin
    2 Miller Dynasty 350's
    Miller Axcess 450
    Miller Syncrowave 350
    Miller XMT 350 CC/CV
    2 Miller XMT 304's
    2 Miller CP250-TS's
    Lincoln Power MIG 300 with
    Cobra Max push-pull gun
    Lincoln WP 250 G9 PRO
  3. #23
    Lake of the Ozarks MO
    3,593
    Thickness could depend on what you have in the way of metal bending stuff.
    If all you can do is just make it slab sided then thicker would be better.
    Baffles can be very tricky to weld in with a tig. They will need "feet" made on them. Good design will help a bunch. I have seen baffles busted loose in big boat gas tanks.
    I would use 5052 for this because it is designed for corrosion resistance unless someone here has a better reason. All sorts of fuel tanks are made with this as well as most fresh water boats. Then you could also use 5356 filler.
    5086 could be a better choice for material as well. It has even better chemical resistance properties. Not sure if you would use any additives in this application. I barely know my job it seems at times.
    I would spend some time thinking about which hardness also.
    You could re-enforce the corners with angle and even weld ribs to the sides and make the bottom so it was forkable.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
  4. #24
    Indiana
    541
    Thank you for the response, alot to think about.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    HH135 mig
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    Harris torch
    beer fridge
  5. #25
    3,593
    So where are we with this project?
    Miller WC-115-A
    Miller Spectrum 300
  6. #26
    Indiana
    541
    Still in the talking stage. The customer has been busy and I have been to.
    I was at his place last night, still on the fence.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    HH135 mig
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    Harris torch
    beer fridge
  7. #27
    3,593
    Quote Originally Posted by tnjind View Post
    Yea I know all about that kinda stuff. Sounds like you might wanna find a way to make it fit his budget and still be nice.
    Ordering the metal already cut to size and bent into 2 channel shapes so it all fits together helps me get the price down. You could use 5052 H-14 and then weld a rib around the perimeter. Maybe use a couple of pieces of channel on the bottom as well.
    You do need a spoolgun for this tho (in a few key spots) IMO. Otherwise you will need to give a ton of thought about the assembly sequence. Or the design. The baffles can be tricky to weld to the slab sides when the metal grows all funky shaped. Clamping and tacking is very important here.
    Knowing when to stop welding and cut stuff back apart is a thing you learn from exp. I can tell now much sooner when bad stuff is gonna happen than say 10 years back
    Miller WC-115-A
    Miller Spectrum 300
  8. #28
    Indiana
    541
    You are a wealth of information. I gotta say I am kinda nervous about this, but I am sure I can do it.
    Yes a spool gun would be nice I am looking for one.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    HH135 mig
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    Harris torch
    beer fridge
  9. #29
    Prairieville, Louisiana
    139
    Smile You can . . .
    You can buy a plastic tank with a steel wire cage for far less than you will ever build that tank . . .
    Steve
    Millermatic 251
    Lincoln AC/DC "Tombstone"
    Milwaulkee Grinder 4 1/2"
    Clark Grinder 4 1/2"
  10. #30
    Indiana
    541
    Quote Originally Posted by Wacko Welder View Post
    Steve
    Yes, I know. I just purchased a 375 gallon plastic tote for hydraulic oil for $175.
    The customer wants it made out of aluminum and a specific shape to make the best use out of the room in the box truck.
    There is no doubt that this will be expensive.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    HH135 mig
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    Harris torch
    beer fridge
