Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: water tank
    Indiana
    541
    Default water tank
    I need to fab. a 4' wide by 5' tall by 3' deep tank to hold water. This tank will be mounted inside a box truck for supply to a concrete cutting saw on site.
    My question is, what material ( I am assuming 6061) and what thickness do I need.
    I do plan on at least one baffle, maybe for support on long side as well as slosh dampening.
    ANY info is greatly appreciated
    Thanks,.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Oct 2009
    306
    If it's going in the back of a work truck I would use 1/8" 6061. If you went any thinner there is a good chance of punching a hole in it. and yes add a baffle or 2 to help support the long wall section of the tank and sloshing when it's full.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Jul 2006
    1,508
    With 3,744 pounds of water, I would definitely go with two baffles minimum! You may want to consider ringing, (at least the middle) of the tank with angle or C-channel.
    Caution!
    Warren PA
    103
    I think i would follow Sonoras baffle/ring advice and use 1/4" material. By my calculations you would need an excessive amount of stiffeners on 1/8". (assuming i did the calculations right )
    2,949
    Default "Ice Cubes"
    Probably more like 450 gallons (if completely full) approx 3735#.
    How about a plastic water tank instead?
    Northern Tools (among other suppliers) have an assortment of tanks around the $300 range.
    Many concrete coring and cutting companies have plastic tanks mounted on the trailer they carry their saws on.
    Just a suggestion
    Dave
    "Bonne journe'e mes amis"
    Jul 2006
    1,508
    Quote Originally Posted by davedarragh View Post
    4’ x 5’ x 3’ x 7.48 = 448.8 gallons
    4’ x 5’ x 3’ = 60 cubic feet.
    Pure water weighs 62.4 pounds per cubic foot.
    Gallon of pure water weighs 8.34 pounds.
    Caution!
    2,949
    Default "Gallons of Gallons"
    You're reading from page 638 of Thomas J Glover's Pocket Reference, I see.
    If a gallon of water weighs 8.333#, and a cubic foot of water contains 7.5 gallons, and a cubic foot of fresh water weighs 62.4#, which is heavier, a pound of steel or a pound of aluminum?
    I'd say, a pound of coffee
    Dave
    Jul 2006
    1,508
    Oh my Gawd, everybody knows a pound of steel is heavier than a pound of aluminum!
    Caution!
    2,949
    Question
    I took a real "pounding" on that one
    Oh, brother...........
    Jul 2006
    1,508
    Caution!
