    Aug 2009
    DFW
    29
    Default Bench Grinder Stand
    I recently bought a bench grinder, and found it inconvenient to leave it on my workbench. I looked into buying one, but the heavy ones were $100+. I got some old harrow discs from a friend, bought a few feet of 3x3 1/8" square and used 9 gauge steel for the mounting plate. A few hours and some spray paint, and I had me a stand for about 30 bucks. I'm relatively new to the forums, so thought I'd share to get something out there.
    Newcastle/Australia
    21
    Default Nice stand
    Hi RL, I like the stand but was wondering if you have any problems with it free standing, I have mine bolted down and would like the ability to move it around as i have a small shop. Does it move under pressure or vibration? If not I might look at doing the same thing with mine, I do a bit of polishing on mine also so I apply a reasonable amount of pressure to the stitch rag.
    Cheers Steve
    Quote Originally Posted by Sparks Downunder View Post
    Hi RL, I like the stand but was wondering if you have any problems freestanding Does it move under pressure or vibration?
    Cheers Steve
    I'd also like to know this, I used a heavy cast plough wheel for one grinder stand and a 20" truck rim for the other.
    Have used a plough disc for a base in other applications many times.
    Feb 2006
    North Platte, NE
    101
    I use a home made stand that is similar. I grind, polish and clean parts with a wire brush with very little movement. It is very nice to be able to move it around the shop. One thing that seems to help both the grinder and my feet is to buy one of the rubber floor mats. Set the stand/grinder on one edge and you have a place to stand off the cement.
    Aug 2009
    DFW
    29
    This turned out to be really sturdy. If I'm putting lot's of pressure on the grinder, I just put one foot on the base of the stand to keep it from potentially moving. The disc ended up being heavy enough for me to keep it stable, but you could always weld heavy plate inside of the concave part of the disc (underneath) for extra weight.
    Quote Originally Posted by Pitalplace View Post
    Great idea for the mat! I may have to do that with mine.
    Newcastle/Australia
    21
    Default sounds good
    Thanks for the reply, i will have to modify mine it will be great to get it out of the way when I need to as my shop is really small .
    Thanks, Steve
    May 2008
    10
    Another option is to use a large (like the ones off my GMC van) disc brake rotor. Those things are very heavy and you can weld the tubing to the top where the axle used to go. Since my auto parts guys don't take them as a core, I find getting rid of them is a pain, and this makes a good way to recycle them.
    Miller AC/DC Thunderbolt
    Lincoln 175HD
    Smith AW1, Dillion Mark III, Smith Little Torch
    Island Falls Maine
    562
    nice way of re useing old junk
    Jan 2009
    Ohio
    191
    Default Picture
    Hey would like to see picture of bench in back ground like the shelf under the bench with 3/4 no9 fem (expanded metal)nice
    Vernon
Tags for this Thread
