    May 2009
    Brandon,MS
    51
    Default homemade sandblaster
    has anyone tried to make a sandblaster? i have a 20" long piece of 10" dia pipe 1/4" wall. i've posted a link to a u-tube video where a guy has made one. my question is, do i need to make the air bypass or can i just run an airline into the top of the tank then bring a hose out of the bottom? what is the purpose of the air bypass?
    http://www.youtube.com/watch?v=q2Q06euHcVI
    Matt
    Syncrowave 200
    Thermal Dynamics Cutmaster 52
    Smithy Midas 1220 Lathe- Mill
    Bandsaw- 20 yr old Harbor Freight type
    Speedglas
    Mar 2009
    Michigan
    138
    Post Blaster
    You will need the air bypass. If you do not use on you will get lots of media with little velocity. The pressure in the tank just gets the blasting media moving, and then the bypassed air accelerates it out the nozzle. For the amount of time and money you spend to make one, you can buy one for $100.00 at the local TSC.
    Miller Syncrowave 200
    Miller Spectrum 875 Plasma Cutter
    Miller Milermatic 135
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Ingersoll Rand, 18.1 cfm Compressor
    30 gal. Sand Blaster
    Planishing Hammer
    150lb Anvil
    10" Swing Logan Lathe
    May 2009
    Brandon,MS
    51
    Default cheap blaster
    that makes sense. thank you.
    Matt
    Syncrowave 200
    Speedglas
    4,457
    I made my blaster, I was cash poor at the time and it made $ sense since they wanted 800$ for one similar. I bought XXH 1/8 pipe nipples, cut them in half for nozzles. Used old pressure washer hose as the abrasive line.
    I didn't use a dead man system to save parts, the tank is 100# LP tank with the top inverted and the fill plug is a rubber grommet from Ford pickup radius arm, fit perfect to plug off a 2 inch pipe.
    Not in the pictures but used an old 1 inch steam valve on the bottom to regulate the sand.
    Island Falls Maine
    562
    good deal looks real good.
