I know there are alot of you hardcore pipe guys on this board.Me not being one of them as many of you know i,m mostly involed in heavy equipment,structural steel.I just finished welding a pipe job mostly 6"and5" and a little 4".This is steam pipe off a oil fired furance.I root passed everything with 1/8" 5P+ lincoln and capped with 7018-H4R 1/8" Excalibur.The contractor who subbed me in tacked/fit all of it together with a 110vFluxcore mig,and said it will see 4psi.I actually called a friend/another welding co owner.and picked his brain and he this is how he does it.Could this have been done with all 5P+?As he stated the code says Lo-Hi 70xx caps welds.Oh and i did snap a couple of pics.
Results 1 to 10 of 16
Thread: Pipe welding question?
10-03-2009, 06:08 PM #1
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
10-04-2009, 08:38 AM #2
Are those welds complete?? If you are a certified welder then you should know what code you need to weld to. If he's hiring as a welder with no ticket or certs in Canada you would be liable if someone gets hurt or property damage. It may only have 4psi working pressure but if something goes wrong in the system the pressure could spike extremely high. I've welded a ton of pipe where they said it's only 2 or 4 psi but could spike as high as 2000psi. So that being said you should look at the drawings and determine what the best plan of action is. Just my opinion ,Jef
10-04-2009, 09:44 AM #3
As if 2 or 4 psi were a welding requirement why cap at all? Just weld it to hold 5 psi ya good to go. Since it be subbed to you then weld the pipe to code. If dude doesn't like it, let him get another sub. Then again do ya trust his flux core fit up?
10-04-2009, 10:03 AM #4
- Apr 2009
- KANSAS
- 511
I agree with Wicked One.
My thoughts: If you are certified then you should be using the prucedure that you're certified under. If thier are no codes or stated procedure, like a WPS, then yes 6010/7018 is a good choice. (By good choice I mean, I would choose it.)
Could it be done with just 6010? Yes
Could it be done with a lot of other rods? Yes
6010/7018 is the industry standard for low pressure in-plant process piping.
Are you re-tacking with 6010 and grinding out the FC tacks?'08 F-350
Vantage 400
SA-250
SA-200
Invertec V350Pro
Invertec V205T-AC/DC
Miller 12VS suitcase
Miller spectrum 2050
Pipe beveler's
Track torch
10-04-2009, 10:11 AM #5
I have certs for D1.1,14.3 and 9.1.I have no certs for pipe, as i stated i,m not big into doing pipe work,i know the rules up north are strictly inforced.I have never seen a drawing on this job again i,m not running it.As for not having pipe certs i have liabilty insurance to protect my intrests/assets.And been welding 23years now so i,m pretty confident i handle this job ok was just looking for a straight answer thats it.... Now can anyone just answer my question about welding it all the way out with 5p+.For some strange reason i knew when i posted on this pipe subject i was gonna take some !@#$.
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
10-04-2009, 10:11 AM #6
Thank you rig hand answer me while i,m typing.
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
10-04-2009, 10:49 AM #7
- Oct 2009
- ri
- 2
I have syncrowave 250 dx
Hi there, i have a problem i need weld aluminum tube 16 gauge and i don't know amperage setting thank you for you help
10-04-2009, 11:12 AM #8
- Apr 2009
- KANSAS
- 511
10-04-2009, 10:17 PM #9
- Oct 2009
- California
- 2
[QUOTE=admweld;Now can anyone just answer my question about welding it all the way out with 5p+.For some strange reason i knew when i posted on this pipe subject i was gonna take some !@#$.
[/QUOTE]
First I would never have anyone tack a pipe weld that I was going to be resposible for, now for your main question. Yes you can weld out from root to cover pass with 5p and for many years most if not all the geothermal steam fields here in the west were welded strickly with 5p. The change over to capping out with 7018 came about in the early 90's but the code is still good, they just stepped it up. There are several hundred miles of 4 to 42" steam line still in service welded this way. Bottom line if your job requires a code to be adhered to, follow the code. Hope this helpsLast edited by Geysers; 10-04-2009 at 10:20 PM.
10-05-2009, 10:34 AM #10
"It may only have 4psi working pressure but if something goes wrong in the system the pressure could spike extremely high. I've welded a ton of pipe where they said it's only 2 or 4 psi but could spike as high as 2000psi."
A steam heating system, if well designed, should never go above 2PSI. The Empire State building is heated with 2PSI. That is why the piping is so large. Relief valves are set at 15 or 30 PSI. If a cast iron boiler spiked to 2000PSI, the boiler itself would explode! Not to mention the fact that most schedule 40 fittings are rated at only 150 PSI. If a low pressure steam heating system hits 5 PSI the system was designed wrong.
RonLRonL
Big Blue 500 CC/CV
CST 280
Hypertherm Powermax 1650
Suitcase 12 RC
24A Feeder
