Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    226
    http://www.sancoclean.com/catalog/ca...no=01010100-GL
    I like this for cleaning alum not to harsh. I mixed up some in a gal bucket and dropped a spool of alum mig wire that was real old in it for a couple of minutes rinsed it of blew it out and let it dry welded like it was brand new I don't know why it wouldn't clean your filler rod a gal will last you a long time and it beats wire brushing or sanding. I buy it at a local cleaning supply.
  2. #22
    Mar 2013
    29
    I bumped up to a 3/4 " cup and I think it solved all of my Woes.
    Acording to the miller Tig Calculator I should use 1/2 to 3/4 cup on 1/4" butt welds.
    I had 5/8 cup but couldnt run a bead larger than a pea with out contamination.
    When in doubt go up a cup size.
