guys, i dont have money for a band saw, and was thinking about making some sort of fixture to where i could use my saws-all, and make the fixture have angle adjustments, like on a band saw table.
i was curious if any of you built anything like this, to give me some ideas.
thanks much.
Thread: Saws-All Cutting Jig ?
09-30-2009, 05:19 PM #1
- Nov 2006
- 346
SyncrowaveŽ 200
Lincoln AC/DC 225/125
09-30-2009, 05:29 PM #2
Good Luck- I would bet the Blade will flop around too much for any precision.
Might as well just scribe the Line and free hand it.
09-30-2009, 06:06 PM #3
- Nov 2006
- 346
i was thinking of some sort of carbide blade guide...
just thinking out loud.SyncrowaveŽ 200
09-30-2009, 06:34 PM #4
You would be better off with a portable band saw. They are reasonably priced and you will get a much better cut with one of those. They are also easy to fixture in a jig like you are planning with your sawzall.
Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
09-30-2009, 06:36 PM #5
- Jan 2008
- 60
yea I think theyre like 60 bucks at harbor freight... I have one and it works great. Im not running it all day every day but have taken on several projects with it and never had a problem.
09-30-2009, 07:30 PM #6
Grizzly sells one that has a stand that converts it into a horizontal. At least they did 4 years ago after I made a vise table and pivot for my HF portaband.
Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
10-01-2009, 05:47 PM #7
- Nov 2006
- 346
10-03-2009, 01:08 AM #8
this is what I use, mostly for Aluminum angle cuts. So far it works great and gives me very nice cuts. The rage3, but they have a cheaper version as well now.
http://www.evolutiononlineshop.com/index.cfmLast edited by Hundguy; 10-03-2009 at 01:13 AM.
10-03-2009, 05:48 PM #9
I have the band saw but have been moving over to a 4 1/2" grinder with a cutoff disk in it. Also bought a Chinese die grinder off internet for .99 cents + $18 shipping...HA! Use a cut off wheel in it. Kind of like a super dremel tool. I had two Sears die grinders before that and this is far superior.
