Results 11 to 20 of 21
    May 2010
    Central CA
    785
    Default Mig
    I always wondered why I couldn't use my Millermatic 90 (sold) to feed my tig. I could use the same gas and feed a dab at a time into the puddle and never have to reposition the rod in my hand.
    I don't know if it's just me or does ED seem have a really big horn.
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Oct 2009
    306
    Setup a cold wire system at a old job welding water purifier stainless tubes on a rotator. Made beautiful welds and saved a ton time.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Jul 2010
    3
    I understand that the TipTig system is a hotwire process
    Jul 2010
    3
    Default tip tig setup
    hi all,
    i have been using tip tig setup for quite a while now, it seems to work very well for what i want it to do.
    it uses 15kg spools of 0.8mm stainless wire, the wire feed units themselves are 4500 here in the uk, thats complete with a 2 button Tip Tig torch (400)
    press the red buton to arc, press the green to start wire.
    our hoses are quite flexible even tho the torch is watercooled, you can still manage to get it into many positions. it also has the ability to be alot quicker than traditional tig methods!
    the output of our Stel welders goes into the back of the Tip Tig unit, then the torch, gas, water, remote wires, all come from the front of it.
    il see if i can upload some photos.
    hope i can help anyone out here, thanks.
    justin
    UK
    Jul 2010
    3
    Smile
    Thanks for your input.
    The pictures are great. I can really see what the Tig Gun looks like.
    I assume this is the "cold process" you are using. Do you why or when you would use the "hot process"
    Cheers
    Quote Originally Posted by justin205 View Post
    hi all,
    justin
    UK
    Jul 2010
    3
    Post
    yes Tallman this is the cold feed.
    there is no arc or power connected to the wire what so ever and is just purely an automatic feed controlled by the microswitch on the tig torch.
    you can control very accurately the wire speed, the oscillation speed, the pause time and the wire retract. certain models are programmable to user settings!
    Tip Tig has a great advantage over feeding the rod by hand because you can put a hec of alot of wire into a weld pool and weld at say, 200A, and your hands are no where near the arc at all so they dont get hot!!
    and also using two hands on the torch gives you a really steady weld that looks amazing!
    could you possibly feed wire manually at about 1ft per 4-5 seconds???
    justin.
    hey for anyone interested still theres a similar system for little over 1k sold by arc zone seems to me that even for this investment it should get good results
    http://www.arc-zone.com/index.php?ma...oducts_id=7852
    Leblond Makino mills
    HAAS CNC SL-40 lathe
    American Pacemaker lathe
    wells index mill
    hydrotel rebuilt
    syncrowave 250
    diversion 165
    Miller Elite Vintage USA
    Jul 2010
    3
    Post
    yeah that seems really cheap, but it is only a wire feed unit that you have to hold in a spare hand.
    where as the Tip Tig has its own dedicated 2 button torch that works the wire unit. your gas runs through the machine, and it even has water cooler connections on the back of the unit because the tip tig torch is cooled. and the wire comes out on a holder that clamps up under your ceramic.
    it seems more of a well thought out machine.,
    however, surely this Pro II Tig cold wire feed can be adapted somehow to be fixed infront of your torch? this way i think it gives you a perfectly straight weld with no great effort or concentration required!
    thanks for the link, it would be interesting to find out how many different styles of adaptable wire feed units there actually are!
    justin
    ya i know its not the ideal setup but it makes it easier to learn and for the price comparably its an "ok" system
    wells index mill
    hydrotel rebuilt
    syncrowave 250
    diversion 165
    Jul 2010
    Default TIP TIG info
    I have found some brochures on a website from Canada.
    http://arcinnovations.net/nmdownloads.php
    some good images of the torches and machines in the brochures.
    It looks like they are the distributor for western Canada.
