Results 1 to 10 of 15
    Millstadt IL
    483
    Default PraxAir proprietary gas question Stargon VS
    I need to renew my bottle leases and happened to see this gas demonstrated at an open house on Friday. I was wondering if any one has experience with StargonVS gas in a 350P machine. Their paper literature has set up parameters for my machine and the weld samples they had looked good but I would still like some real world user input. Thanks, JEFF
    200DX 350P 625 Plasma & other stuff I forgot
    southern California
    1,783
    What is the mix ratio?
    Miller tested the 350P and found it to run best on 90/10 Ar/CO2, which is what they recommend to use in the manual. When I talked to them about using alternative mixes, they said that in testing the 350P with various other gas mixes, their second choice is 95/5 Ar/CO2. I asked them about using 92/8 Ar/CO2 and 98/2 Ar/O2 and they didn't recommend those or anything else. I have always mine on 98/2 and it does take some adjusting of the settings to make it run good. Next time I have the bottle filled, I'm going to try 95/5.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Jul 2008
    Delhi, Ontario:
    1,950
    Default Stargon VS.
    Quote Originally Posted by Desertrider33 View Post
    Desert; I think " Stargon VS " by Praxair is - 82% Argon- 10%Helium-8%Co2
    I could be wrong, but that is what I was lead to believe ?
    .............. Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
    May 2009
    Ottawa Canada
    494
    Default Stargon CS or Stargon SS
    Good evening everyone,Stargon CS for steel is 90%Argon/8%co2/2%oxygen.Possible typo maybe?For SS Stargon SS is 80%argon/10%co2/10%Nitrogen,Frank
    Millermatic 252
    Millermatic 180
    Hobart spoolmate 3035
    Digital Elite
    Jul 2008
    Delhi, Ontario:
    1,950
    Quote Originally Posted by Frank Motoweld View Post
    Frank , Hi; I dunno, there was a thread about this quite a while ago, I just jotted it down. Now that I think about it , it was for Stainless Steel ?
    To be honest I can't remember ? Yes I'm looking at my notes, the other reference was to your first example of Helium 90%- Co2- 8% & O2- 8% ?
    .............. Norm : PS. I hope you are Not as Confused as I am !!!
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
    2,636
    Gas Blends
    » Starblend™ Gas Mixing System
    » StarGold™ Blends
    - Argon-Carbon Dioxide Mixtures -- Praxair's StarGold™ and Mig Mix Gold™ Blends
    - Argon-Oxygen Mixtures -- Praxair's StarGold™ Blends
    » Stargon™ Blends
    - Argon-Carbon Dioxide-Oxygen Mixtures -- Praxair's Stargon® CS Blend
    - Argon-Carbon Dioxide-Nitrogen Mixtures -- Praxair's Stargon® SS Blend
    » HeliStar™ Blends
    - Argon-Helium-Carbon Dioxide Mixture -- Praxair's HeliStar® GV Blend
    - Argon-Helium Mixtures -- Praxair's HeliStar® Blends
    - Argon-Helium-Carbon Dioxide Mixtures -- Praxair's HeliStar® Blends
    » HydoStar™ Blends
    - Argon-Hydrogen Mixtures -- Praxair's HydroStar® Gas Blends
    - Argon-Carbon Dioxide-Hydrogen Mixtures -- Praxair's HydroStar® Gas Blends
    » LaserStar™ Blends
    - Praxair's LaserStar™ Gases and Blends For Optimum Laser Performance
    » RoboStar™ Blends
    - Argon-Carbon Dioxide-Oxygen -- Praxair's RoboStar® CS Blend
    - Argon-Helium-Carbon Dioxide -- Praxair's RoboStar® SS Blend
    - Argon-Helium -- Praxair's RoboStar® AL Blend
    http://www.praxair.com/praxair.nsf/7...4?OpenDocument
    Norm,
    I stopped with notes a long time ago- just Bookmark my Reference pages-clickity click
    2,636
    Quote Originally Posted by jeffscarstrucks View Post
    best real world user is You- heck you were right in front of the Demo, what is an E-Opinion gonna do
    Jul 2008
    Delhi, Ontario:
    1,950
    Talking Note Taking ??
    Gas Blends
    » StarGold™ Blends
    » Stargon™ Blends
    » HeliStar™ Blends
    » HydoStar™ Blends
    » LaserStar™ Blends
    » RoboStar™ Blends
    Norm,
    OK, Ed; Will Do ! Ed , Prior to 1-1/2 yrs. ago I'd never touched a computer ! Still learnin' how to use this thing ?
    Back to the Gas Blends, Do you think they have enough ??
    .............. Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
    May 2009
    Ottawa Canada
    494
    Default Enough gases?
    Hey Norm,as if its this is not enough,you can go in there and one time your C-25 will be called Autoweld,the next time it'll be called Stargold etc...
    Millermatic 252
    Millermatic 180
    Digital Elite
    Jul 2008
    Delhi, Ontario:
    1,950
    Exclamation Too Many Names !!
    Frank, I tell-em I want a tank of C-25, way too many names for me !!
    ............... Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
