Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    8
    Default just ordered the bernard gun
    I just ordered a bernard gun for my mm175 cant wait for it to arrive
    Nov 2005
    Central Al
    8
    Mikemcc; I too have an MM175, and will be getting an replacement gun/cable assy.mine was damaged in a fire. Been looking at the M-25 15' at $191.00 + shipping. However I'm not familuar with the 'Bernard' unit. In what respect is this one your ckoise? I may consider it too. TIA for ya comment. Al
    8
    free upgrade from our friends at bernard
    check out the home page in the right lower corner..
    select the gun then give them a call
    Edmonton, AB CANADA
    53
    Quote Originally Posted by mikemcc
    I thought that was for the industrial welders only? They did the swap for free on your MM175? Which gun did you get? All the options on their guns make it hard to choose.
    8
    Talking
    just recieved it in the mail
    it is for all miller welders personal or industral
    i got the Q15 20 A O 8B M
    you can order any combo you need..
    it comes with 10 consumables also
    cool
    8
    Talking
    opps this is the breakdown for the order
    Q15 : 150 amps
    20 : 20 ft. (6.16 m) cable
    A : 150 Amp Curved Handle, Standard Trigger
    O : Fixed, Short 45° QT2-45 neck
    8B : 0.030" (0.8 mm) T-030 Centerfire contact tip
    M : Miller® direct plug style
    Feb 2006
    springvale me
    89
    your going to like it a hole lot much more beefy than most guns and cables it has held up extremely well for me on a portable set up
    Aug 2002
    Appleton, WI
    209
    To clarify...
    As part of the integration of Bernard guns with select Miller products, Bernard introduced the “Choose Your Weapon” Gun Exchange Program to ensure complete satisfaction. If your Miller industrial feeder or MIG system came bundled with a Bernard Q-Gun and it does not fit your needs or application, Bernard will exchange the MIG gun - at no additional cost - for any other configurable, air-cooled Bernard MIG welding gun.
    To find configuration options for a replacement gun, call Bernard customer service at 1-800-946-2281 (US) / 708-946-2281 (outside of US), use their online CustomSelect Ordering System, or the Q-Gun user guide.
    866
    Q15 : 150 amps
    I sure hope that 20 ft length doesn t end up burning up the little feeder motor on your MM 175.
    Dec 2005
    375
    Question I'm confused?!!
    I'm confused because from what I've read and after talking to Heidi over at Bernard.."mikemcc" Should not have gotten a Bernard gun exchange unless he ordered his MM175 with a Bernard gun from the start. if he had the standard miller gun that normally comes on a MM175 he wouldn't be eligible for a Bernard gun. Anyone else have any information on this..Administrator?
    Mike can you explain more?
    Regards, Farris
    confused!
    Gone But Never Forgotten!
