Results 1 to 10 of 10
Thread: arc gouging
    Default arc gouging
    What exactly is arc gouging? I've searched to learn about it and also watched some videos on youtube but still not quit sure. I have a xmt304 and it says it's capable of arc gouging but I don't see anything about it under accesories. I believe I need a torch/rod holder of some kind but not sure what else I will need.
    Also what is arc gouging good for? Can it do everything a plasma cutter can or is more like a torch that give rough cuts?
    Thanks for helping out a newbie with this!
    2,949
    Default Cac-a
    Quote Originally Posted by ponch37300 View Post
    Do a search for Carbon Arc Cutting or Carbon Arc Gouging and it will bring up a whole list of links.
    Dave
    "Bonne journe'e mes amis"
    southern California
    1,783
    You need a very powerful air compressor, and a gouging torch, like one from Arcair. The carbon electrode provides the arc to melt the metal and the compressed air blows the metal away. It's a rough cut process good for demolition and getting rid of unwanted welds on thick metal. It's not a substitute for a fine cutting plasma, but can be a substitute for a gas cutting torch.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Jul 2006
    1,508
    I feel a plasma torch in the scarf mode is cleaner, but the long carbon rods have an advantage. Like reaching into a hole or very tight spot. The longer the stick out of the rod from the carbon arc torch the more air, and amps youíll need.
    2,949
    Default Arc Air Rods
    The smaller diameter rods (3/32, 1/8...) are also very delicate. I "grab" them in the middle with the stinger, but it's still easy to mess them up, especially after they've gotten hot.
    Dave
    Thanks for the knowledge guys. I was kinda hoping it would be like a plasma but guess I'm out of luck! So it sounds like arc gouging cuts like a acetyline torch?
    southern California
    1,783
    Yeah they do get brittle after they get red hot.
    It's not a clean cut but it does the job.
    Millermatic175
    HTP MIG200
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -Bobcat 250NT
    -PassportPlus/Q300
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Jul 2006
    1,508
    Jun 2009
    greenfield new hampshire
    889
    Default good pencils
    great tool for back grinding butt joints for 100% weld, side shell, or hull on steel boats/ships are welded from inside then gouged out from the outside for welding, alot quicker than grinding
    West Farmington, OH
    746
    I like gouging for disassembly of weldments you can gouge the weld and save the parts you need to re-use. I've done a lot of backhoe sticks and booms where I've gouged the bushings and etc... from them and welded them back onto the new boom or stick. Have done a lot of arms for the railroad for the machine that pulls out the old rail ties. As others have said it's great for back gouging for full penetration welds, it's also good for doing repairs to welds which have failed an x-ray test as well. It's not good for cutting parts or anything like that a torch does a much cleaner job.
