I have always wanted to build a tear drop camping trailer to pull behind my mini cooper. Currently i am enrolled in a tech school for welding and we get to make a final project in metal fab class. This is what i was thinking. i have a trailer all ready and just build a cabin to sit on top. One inch square aluminum tubing really thin walled as thin as i can go build the frame out of it then skin it with AL sheet like 20 gage. then foam for insulation on the inside then more al sheet for inside the walls. the key is as light as possible. Any ideas thoughts concerns please share them. im not totally sure what im getting myself into any thoughts would be greatly appreciated. Thank you in advance,
Results 1 to 10 of 20
09-21-2009, 05:57 PM #1
Want To build a Teardrop camping trailer
09-21-2009, 07:41 PM #2
Sounds like you have a good plan so far...Bob
http://www.teardroptrailers.net/part...s/trailers.htmLast edited by aametalmaster; 09-21-2009 at 07:43 PM.
09-22-2009, 01:18 AM #3
- Oct 2008
- 5
I actually used to have something similar. I had a old 1930's tear drop trailer that was aluminum skin and shelving with 1/2 angle iron steel frame. It was light enough I could maneuver the shell around myself until I installed the flooring anyway. I ended up giving it to my brother who decided to cover everything with tin for whatever reasons.
From that experience, I think your framing and exterior covering materials are good choices. Hopefully you can find foam that is an inch thick so your interior walls aren't thicker than they need to be. If I may suggest though, the floor and interior are where your weight is really going to add up. I used 3/4" plywood for my floor, but I wasn't as concerned about weight as you are. I also spent quite a bit of time inside an unfinished teardrop with bare aluminum walls- it was noisy. Perhaps you should consider interior wall of bamboo paneling. It's relatively light weight, super strong, and would add a unique look to what will be a unique camper and car combination.
09-22-2009, 05:12 PM #4
Thank your for the suggestion i probably will use some sort of paneling on the inside not the metal that was one of my concerns noise how loud it would be. any idea any one on how thin i can go on the tubing and will like 20 gage sheet stay flat if welded on every foot? thanks
09-22-2009, 10:59 PM #5
- Mar 2006
- Chicago-ish
- 282
I always thought that this would make a cool streamlined trailer. If it was there in my drinking days, I might even have tried to hitch it up.
09-22-2009, 11:20 PM #6
- Jul 2007
- 241
09-23-2009, 12:47 AM #7
It has 168 plates welded together...Bob
http://en.wikipedia.org/wiki/The_BeanBob Wright, Grandson of Tee Nee Boat Trailer Founder
09-23-2009, 12:28 PM #8
I would not be looking to weld the flat sheet to the frame of anything.
You will end up with a twisted mess. 20gs sheet welded every foot the weld will telegraph to the outside with a pucker.
Think adhesive.
Bolt the aluminum frame together and use industrial urethane adhesives to attach the skin to the frame, and the paneling to the inside.
09-23-2009, 01:32 PM #9
- Feb 2009
- Lodi, CA
- 1,126
Time for a little reading, from people who have done it ....
http://www.hobartwelders.com/weldtal...light=teardrop
http://www.mikenchell.com/forums/
http://www.teardrops.net/
It took me two minutes to find these, copy and paste here. With a little effort, should be easy to find plenty of other sources of information.
09-23-2009, 01:51 PM #10
Look up vids on youtube of RV-7 riveting. The skin will look sweet with AN426 rivets, and you'll have a blast installing them.
