Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 64
  1. #31
    Dec 2008
    Arizona
    812
    Default Coming Along Nicely
    The panels look great. The one that has the brace going through it (right below the intercooler piece)...I didn't see a break in the brace or panel to get the tube through it. How????
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
  2. #32
    Dec 2006
    612
    Quote Originally Posted by nocheepgas View Post
    When I put those braces in I wondered how I could get a clean look at the firewall. So, I welded a plug in the end of the tube, cut it to fit, then drilled & tapped it. I ran a bolt through a gusset welded in the chassis, then welded the font of the tube to the strut brace. It's a tight fit, but I then just removed the blot & slid the panel behind it.
  3. #33
    Dec 2006
    612
    Everybody (but me) had to work this weekend, we celebrated Father's day Thursday, so I had the weekend to work on the firewall. Got a fair amount done.
    Since this WILL be a street legal car, I found a new spot to display the trim code tag.
    I stuffed it between the strut tube & the inlet side of the intercooler.
    Also made paper patterns for a couple more pieces of the puzzle.
  4. #34
    Dec 2006
    612
    I decided to stamp a "Camaro: logo in the driver's side panel
    The press and bead rolling oil canned the panel a little but I think it will straighten out when I put the 7/8" tabs on the top & bottom with the brake.
    It came out fairly clean, even the little piece in the top of the "o" stamped. That part was about 1/2 the size of a pencil eraser. When I paint the firewall I'll paint the logo over this, the stamping will give it a little extra "pop".
  5. #35
    Mar 2009
    Corona, CA
    213
    I only have one word. ****.
    As seems to be the trend...that looks awesome, and is starting to really come together.
    I wish I had a CNC machine, and a home shop...
    Precision is only as important as the project...if you're building a rocket ship...1/64" would matter. If you're building a sledgehammer...an 1/8" probably wont.
  6. #36
    Dec 2008
    Arizona
    812
    Default I'm Impressed!
    The title says it all, but not nearly effective enough to compliment you on your work. Looking awesome!
    130XP MIG
    Spectrum 375
  7. #37
    Dec 2006
    612
    Thanks on fire & nocheepgas. I appreciate the compliments.
    The more I looked at the Camaro panel the more things I found I didn't like. The deal breaker was when the bead rolled lines didn't match up to panel next to it. So, tonight I knocked out another one. It didn't take long since I had the stamp & measurements from the first "prototype". [ prototype = politically correct term to describe "junk part"]. I had to lay the panels in place to see how it was going to look. There's a lot of massaging to be do to get everything to fit, but it is getting closer.
  8. #38
    Jan 2007
    Delmont, PA
    290
    Hey pro-z,
    From an 'ol timer, I wanted to commend you on your project with layout & execution. I've been watching since your first post. Your posting of progression is superb & I'm sure many youngsters/newbies contemplating such an undertaking will appreciate your efforts. Since I do 6-8 classic/show car resto's a year, I can see you are talented with your quality approach to do it right the first time. Kudos....
    Denny
    * Complete welding, machine, & fab shop *
    * Mobile unit *
    * Finally retired *
    ____________________________________________
    * A man's word is his honor..... without honor, there is nothing. *
    * Words are like bullets..... once they leave your muzzle, you cannot get them back. *
    * I have no reservation to kill nor hesitation to die for the U.S. Constitution & the American Flag. *
    * Age is a state of mind..... at my age, you cannot fathom what is in my mind. *
  9. #39
    May 2008
    OCEANSIDE, CA
    123
    Wow! Beautiful work
    DYNASTY 200SD
    COOLMATE 1
    MM140AS
    SPOOLMATE 100
    SPECTRUM 625 X-TREME
    SPECTRUM 125C
  10. #40
    Dec 2006
    612
    Thanks UH60LCHIEF
    Denny, thanks for the comments. Your right it is a lot of work but it's a good way to get away from the grind from time to time.
