The panels look great. The one that has the brace going through it (right below the intercooler piece)...I didn't see a break in the brace or panel to get the tube through it. How????
Results 31 to 40 of 64
Thread: Firewall project
06-14-2010, 08:46 PM #31
Coming Along Nicely
Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
06-14-2010, 09:29 PM #32
- Dec 2006
- 612
When I put those braces in I wondered how I could get a clean look at the firewall. So, I welded a plug in the end of the tube, cut it to fit, then drilled & tapped it. I ran a bolt through a gusset welded in the chassis, then welded the font of the tube to the strut brace. It's a tight fit, but I then just removed the blot & slid the panel behind it.
06-20-2010, 08:14 PM #33
- Dec 2006
- 612
Everybody (but me) had to work this weekend, we celebrated Father's day Thursday, so I had the weekend to work on the firewall. Got a fair amount done.
Since this WILL be a street legal car, I found a new spot to display the trim code tag.
I stuffed it between the strut tube & the inlet side of the intercooler.
Also made paper patterns for a couple more pieces of the puzzle.
06-20-2010, 08:30 PM #34
- Dec 2006
- 612
I decided to stamp a "Camaro: logo in the driver's side panel
The press and bead rolling oil canned the panel a little but I think it will straighten out when I put the 7/8" tabs on the top & bottom with the brake.
It came out fairly clean, even the little piece in the top of the "o" stamped. That part was about 1/2 the size of a pencil eraser. When I paint the firewall I'll paint the logo over this, the stamping will give it a little extra "pop".
06-22-2010, 10:34 PM #35
- Mar 2009
- Corona, CA
- 213
I only have one word. ****.
As seems to be the trend...that looks awesome, and is starting to really come together.
I wish I had a CNC machine, and a home shop...Precision is only as important as the project...if you're building a rocket ship...1/64" would matter. If you're building a sledgehammer...an 1/8" probably wont.
06-25-2010, 07:19 PM #36
I'm Impressed!
The title says it all, but not nearly effective enough to compliment you on your work. Looking awesome!
130XP MIG
Spectrum 375
06-25-2010, 08:54 PM #37
- Dec 2006
- 612
Thanks on fire & nocheepgas. I appreciate the compliments.
The more I looked at the Camaro panel the more things I found I didn't like. The deal breaker was when the bead rolled lines didn't match up to panel next to it. So, tonight I knocked out another one. It didn't take long since I had the stamp & measurements from the first "prototype". [ prototype = politically correct term to describe "junk part"]. I had to lay the panels in place to see how it was going to look. There's a lot of massaging to be do to get everything to fit, but it is getting closer.
06-26-2010, 07:53 PM #38
Hey pro-z,
From an 'ol timer, I wanted to commend you on your project with layout & execution. I've been watching since your first post. Your posting of progression is superb & I'm sure many youngsters/newbies contemplating such an undertaking will appreciate your efforts. Since I do 6-8 classic/show car resto's a year, I can see you are talented with your quality approach to do it right the first time. Kudos....
Denny* Complete welding, machine, & fab shop *
* Mobile unit *
* Finally retired *
____________________________________________
* A man's word is his honor..... without honor, there is nothing. *
* Words are like bullets..... once they leave your muzzle, you cannot get them back. *
* I have no reservation to kill nor hesitation to die for the U.S. Constitution & the American Flag. *
* Age is a state of mind..... at my age, you cannot fathom what is in my mind. *
06-26-2010, 08:50 PM #39
- May 2008
- OCEANSIDE, CA
- 123
Wow! Beautiful work
DYNASTY 200SD
COOLMATE 1
MM140AS
SPOOLMATE 100
SPECTRUM 625 X-TREME
SPECTRUM 125C
06-27-2010, 08:30 PM #40
- Dec 2006
- 612
Thanks UH60LCHIEF
Denny, thanks for the comments. Your right it is a lot of work but it's a good way to get away from the grind from time to time.
